QCad CAM
- emcPT
- Thank you received: 139
16 Nov 2013 23:08 #40868
by emcPT
If this was for me, please see that I made it in 2006. No CAM in that time.
I wrote a program that opens the dxf and retrieves lines and arcs. Then it groups lines and arcs that are connected to produce continuous parts. When the shape is disconnected it is another "part" that means that a new pierce occurs. Really simple and effective if the user uses correctly the CAD part.
Replied by emcPT on topic QCad CAM
I would be interested in looking at your QCad CAM configuration.
JT
- BigJohnT
- Thank you received: 1175
16 Nov 2013 23:41 #40870
by BigJohnT
It would still be interesting to see how you did it. What language did you use?
JT
Replied by BigJohnT on topic QCad CAM
JT
JT
- emcPT
17 Nov 2013 00:03 #40871
by emcPT
PM sent.
- Sterling
24 Nov 2013 08:26 - 24 Nov 2013 08:27 #41139
by Sterling
Replied by Sterling on topic QCad CAM
Hmm...Hopefully I can download the new ver and test the drilling soon~!
Last edit: 24 Nov 2013 08:27 by Sterling.
- Sterling
24 Nov 2013 10:30 #41141
by Sterling
I'm *really* excited to see how this works~!!
Instead of re-drawing everything, I'm going to import a pre-existing image and see if it will properly render the code & drilling holes.
Have you tested this yet? Any word on what is needed for a "drilling point"? Just a dot/pixel? A small filled circle? (I intend to look over the manual but I have found that documentation has a tendency to fall short in complete explanation, and wanted to touch base here as well).
Thanx~!
I've downloaded and installed 3.4.3.Just a note to anyone that might be following this thread QCad version 3.4.3 now exports points properly for drilling holes.
JT
Thanx~!
- BigJohnT
24 Nov 2013 20:45 #41145
by BigJohnT
When you open QCad the upper left button with the 3 +'s on it is points. When you create a drawing with points and export the cam it will rapid to each point then feed down to Z cutting then rapid up to Z Clear then rapid over to the next hole. When you click on the hole the Draw Order in the Property Editor is the order that the holes will be drilled. If you have spindle control in LinuxCNC you will need to add the M3 Sn and M5 to turn the spindle on and off.
I need to try and add the spindle option to the mill configuration.
JT
JT
- Sterling
02 Feb 2014 08:54 #43417
by Sterling
Okay, I've re-downloaded QCAD (two computers, a couple holidays and a bunch of other "real Life" situations later...)
and I have a question;
I have never done anything regarding a "Tool Table, "Tool set" or "Tool Offset". So, when I draw these objects in QCAD, do I need to increase the size of the object by the router bit? That is how I've always done it when doing the programming by hand.
I did not see anything in the QCAD help file when I looked.
Thanx -
Thanx -
- BigJohnT
02 Feb 2014 21:06 #43433
by BigJohnT
That is a straight forward way to get the correct tool path. Offset the path by 1/2 of the tool diameter on a new layer. You can even round the corners of the tool path to get a proper corner.
JT
JT
- Sterling
02 Feb 2014 21:55 - 02 Feb 2014 21:56 #43434
by Sterling
Half the tool? Why not the whole width? I'd think that while carving it out, you'd want to use the 'edge' of the router bit as your border...
Last edit: 02 Feb 2014 21:56 by Sterling.
- Sterling
03 Feb 2014 00:13 - 03 Feb 2014 00:13 #43444
by Sterling
I decided to scale the drawing.
I've drawn it out in QCad, and figured - why not increase the scale according to the difference of the router bit?
Example =
#1) The piece I am cutting is an "L" bracket that is 210mm long, and 30mm high.
#2) I will be using a 6.35mm diameter bit (.25" ).
#3) With a .25" bit, the dimensions should be 216.35mm (L) & 30.9mm, (H) right?
#4) The difference is 3%
#5) Ergo, I would 'Scale" the drawing by in incrementation of 3%. (1.03 in the scaling window). Right?
Example =
Last edit: 03 Feb 2014 00:13 by Sterling. Reason: (typo)
Time to create page: 0.098 seconds
