QCad CAM
- Sterling
09 Apr 2014 06:19 - 09 Apr 2014 06:20 #45726
by Sterling
Replied by Sterling on topic QCad CAM
I just drew up a bunch of shapes in QCAD and it suddenly occurred to me that I did not allow for the diameter of the router bit. (oops)
I've never used the Tool Table in Linux CNC. Will that provide the proper offset or do I need to redraw everything?
(Lesson learned!)
>>> Sterl
(Lesson learned!)
>>> Sterl
Last edit: 09 Apr 2014 06:20 by Sterling.
- jmelson
- Thank you received: 158
09 Apr 2014 10:27 #45734
by jmelson
cutter radius compensation, and then add in the G41 or G42 commands after
placing the cutter at the safe starting point, and a G40 before moving to the
safe stopping point. If you are cutting an outside shape, your safe starting point
is slightly less than the expected cutter radius outside a line extending from
the part outline, and at least a cutter radius beyond the part along that line.
Pretty much the same for the safe stopping point. When the cutter radius
comp. is turned on, what would normally be an angled line toward the part
becomes a nearly straight line tangent to the part outline as the cutter
comp in interpolated in along the length of the move.
LinuxCNC is very picky about there not being an inside corner when cutting
the OD of a part with radius comp. so the selection of the start and stop
point is pretty tricky. Once you've done it a couple times, it gets easier.
There is some info in the docs at :
linuxcnc.org/docs/html/gcode/tool_compen...:cutter-compensation
Jon
Replied by jmelson on topic QCad CAM
You need to provide properly placed lead-in and lead-out moves to be able to useI just drew up a bunch of shapes in QCAD and it suddenly occurred to me that I did not allow for the diameter of the router bit. (oops)
(Lesson learned!)
>>> Sterl
Jon
- Sterling
09 Apr 2014 10:50 #45737
by Sterling
Groovy, thanx!
Yes - it's all outer diameter stuff. It is more time consuming and embarrassing really...I will most likely re-draw the shapes in QCAD, adding .125" (I'm using a .25" bit)
>>> Sterl
>>> Sterl
- BigJohnT
- Thank you received: 1176
09 Apr 2014 18:56 #45751
by BigJohnT
Replied by BigJohnT on topic QCad CAM
You can use the Parallel with distance line tool to offset both lines and arcs. I like to create a new layer for tool path and offset to that layer. This way if I want to use a different tool I just create a new layer for that tool.
JT
JT
- Sterling
09 Apr 2014 19:27 #45753
by Sterling
It appears that I ought purchase that help-book I saw on-line. After all, I'll be turning 50 in a few weeks, this might be an excellent present to myself!
Thanx -
>>> Sterl
Hmmm...That's a new one. I'll check it out, thanx.You can use the Parallel with distance line tool to offset both lines and arcs. I like to create a new layer for tool path and offset to that layer. This way if I want to use a different tool I just create a new layer for that tool.
JT
Thanx -
>>> Sterl
- tenaja
- Thank you received: 5
09 Apr 2014 21:28 #45761
by tenaja
Replied by tenaja on topic QCad CAM
Based on my experience with machines with Fanuc controllers, I can tell you that the learning curve will be well worth it. Imagine you set up a toolpath, and half way through you break the only 1/4" tool you have. Using the tool table, you can swap out the tool for a 3/8" and be cutting with the same gcode within moments.Groovy, thanx!
>>> Sterl
- jmelson
09 Apr 2014 23:06 #45765
by jmelson
in the software to automatically create a new outline that is offset from
what you drew. They call this a different thing on every package, so
I can't tell you the exact name of the command.
Jon
Generally, you don't have to redraw the shape, there ought to be a featureGroovy, thanx!
>>> Sterl
Jon
- Sterling
27 Apr 2014 22:38 #46378
by Sterling
Need some help here -
I just bought, downloaded and installed the Pro version of QCAD. I installed it on my Windows machine, QCAD version 3.4.7.0.
I wanted to put in your Linuxcnc Cam export, but when I opened up the file location, I discovered that the path...
There is a directory
\Program Files (x86)\QCAD\scripts\
that contains *.js files, but...I'd rather not experiment and just drop the file a folder and hope it works!
Thoughts?
Thanx -
>>> Sterl
...does not exist...Place in the scripts/Cam/CamConfigurations directory.
Thoughts?
Thanx -
>>> Sterl
- Sterling
28 Apr 2014 05:37 #46394
by Sterling
Oh drat!
I purchased the QCAD PRO not the QCAD +CAM version. And I do not see a +CAM add on.
I will be sorely disappointed if a re-purchase is required and they not allow for an upgrade!
>>> Sterl
>>> Sterl
- BigJohnT
28 Apr 2014 18:29 #46424
by BigJohnT
The windows install will likely use different directories.
I hope they treat you right on the CAM part.
JT
JT
Time to create page: 0.070 seconds
