2.7
- Diederik
04 Mar 2015 22:59 #56464
by Diederik
2.7 was created by Diederik
I just updated to 2.7, now get the following error:
hm2/hm2_5i25.0: warning: sserial remote device 7i77 channel 0 has old firmware that should be updated
how and where? I know I need to flash it somehow, but I can't find any instructions on how to do this.
Kind regards,
Diekie
Kind regards,
Diekie
- Thank you received: 5203
05 Mar 2015 00:42 #56470
Replied by PCW on topic 2.7
www.mesanet.com/software/parallel/sserial.zip
Has the firmware and scripts for updating sserial remote firmware
Unzip and read the README file for instructions
The following user(s) said Thank You: Diederik
- Diederik
05 Mar 2015 00:56 #56471
by Diederik
thank you very much
Replied by Diederik on topic 2.7
- Diederik
10 Mar 2015 18:54 - 11 Mar 2015 21:49 #56614
by Diederik
I tried to do everything as per instructions on readme, but keep getting the errors.
in terminal, I get the following:
ptd001@ptd001:~/sserial/utils/linuxcnc$ sudo ./update7i77
move 7I77 W4 and W12 to right hand positions
cycle 7I77 field power and 5V power and hit return
read: 3: arg count
updating 7I77 field I/O
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/setsserial.ko': -1 Operation not permitted
update7i77d.hal:4: exit value: 1
update7i77d.hal:4: insmod failed, returned -1
See the output of 'dmesg' for more information.
ERROR: Module setsserial does not exist in /proc/modules
<commandline>:0: exit value: 1
<commandline>:0: rmmod failed, returned -1
<commandline>:0: unloadrt failed
updating 7i77 analog out
update7i77a.hal:4: exit value: 1
update7i77a.hal:4: insmod failed, returned -1
now move 7I77 W4 and W12 to the left hand positiona
and cycle field power and 5V power
Please tell me what I am doing wrong?
read: 3: arg count
Last edit: 11 Mar 2015 21:49 by Diederik.
10 Mar 2015 20:40 #56618
How did you install linuxcnc 2.7?
if this is a run-in-place install you must run the run-in-place script before running the firmware update script
(It looks like you are running an earlier linuxcnc version that does not have setsserial)
- Diederik
10 Mar 2015 20:43 #56619
by Diederik
I used software sources according to the instructions I found on web.
- Diederik
10 Mar 2015 21:03 - 11 Mar 2015 21:49 #56622
by Diederik
ptd001@ptd001:~/sserial/utils/linuxcnc$ cd /usr/realtime-2.6.32-122-rtai/modules/linuxcnc/
ptd001@ptd001:/usr/realtime-2.6.32-122-rtai/modules/linuxcnc$ ls
5axiskins.ko counter.ko hm2_test.ko mux16.ko sim_encoder.ko
abs.ko ddt.ko hostmot2.ko mux2.ko sim_home_switch.ko
abs_s32.ko deadzone.ko hypot.ko mux4.ko sim_parport.ko
and2.ko debounce.ko ilowpass.ko mux8.ko simple_tp.ko
at_pid.ko edge.ko integ.ko mux_generic.ko sim_spindle.ko
axistest.ko encoder.ko invert.ko near.ko sphereprobe.ko
bin2gray.ko encoder_ratio.ko joyhandle.ko not.ko stepgen.ko
biquad.ko estop_latch.ko knob2float.ko offset.ko steptest.ko
bitslice.ko feedcomp.ko latencybins.ko oneshot.ko streamer.ko
bitwise.ko flipflop.ko lcd.ko opto_ac5.ko sum2.ko
bldc_hall3.ko gantrykins.ko limit1.ko or2.ko supply.ko
bldc.ko gearchange.ko limit2.ko orient.ko thc.ko
blend.ko gearselect.ko limit3.ko pci_8255.ko thcud.ko
boss_plc.ko genhexkins.ko lincurve.ko pcl720.ko threads.ko
charge_pump.ko genserkins.ko logic.ko pid.ko threadtest.ko
clarke2.ko gray2bin.ko lowpass.ko pluto_servo.ko timedelay.ko
clarke3.ko hal_ax5214h.ko lut5.ko pluto_step.ko timedelta.ko
clarkeinv.ko hal_evoreg.ko maj3.ko pumakins.ko time.ko
classicladder_rt.ko hal_gm.ko match8.ko pwmgen.ko toggle2nist.ko
comp.ko hal_lib.ko matrix_kb.ko rotatekins.ko toggle.ko
constant.ko hal_motenc.ko maxkins.ko rtapi.ko tripodkins.ko
conv_bit_s32.ko hal_parport.ko mesa_7i65.ko sample_hold.ko tristate_bit.ko
conv_bit_u32.ko hal_ppmc.ko mesa_uart.ko sampler.ko tristate_float.ko
conv_float_s32.ko hal_skeleton.ko message.ko scale.ko trivkins.ko
conv_float_u32.ko hal_speaker.ko minmax.ko scarakins.ko updown.ko
conv_s32_bit.ko hal_stg.ko modmath.ko scope_rt.ko watchdog.ko
conv_s32_float.ko hal_tiro.ko motmod.ko select8.ko wcomp.ko
conv_s32_u32.ko hal_vti.ko moveoff.ko serport.ko weighted_sum.ko
conv_u32_bit.ko hm2_7i43.ko mult2.ko setsserial.ko xhc_hb04_util.ko
conv_u32_float.ko hm2_7i90.ko multiclick.ko siggen.ko xor2.ko
conv_u32_s32.ko hm2_pci.ko multiswitch.ko sim_axis_hardware.ko
ptd001@ptd001:/usr/realtime-2.6.32-122-rtai/modules/linuxcnc$ sudo source installss
sudo: source: command not found
It seems like I do have setsserial.ko
10 Mar 2015 21:24 #56625
Are the firmware bin files installed?
- Diederik
10 Mar 2015 21:27 #56626
by Diederik
I'm going to check it out quick.
- Diederik
10 Mar 2015 21:45 - 11 Mar 2015 21:47 #56627
by Diederik
I'm trying to install, but getting a syntax error
I get the following when trying to install BIN files:
Last edit: 11 Mar 2015 21:47 by Diederik.
Time to create page: 0.145 seconds
