Starting over
10 years 4 weeks ago #81159 by Patrick Obrien
Replied by Patrick Obrien on topic Starting over
andypugh wrote: This setup should be really very close:
Since Launch test panel did't work I tried Test/Tune Axis. I ran into a snag with pncconf @ test/tune. I suspect it is my error but I am not that far into pncconf.config yet. Any hints?
10 years 4 weeks ago #81172 by andypugh
Replied by andypugh on topic Starting over
I think that error is an actual bug.
github.com/LinuxCNC/linuxcnc/issues/159
Try skipping the test/tune part, then worry about it if the axes don't actually move with the final config.
10 years 4 weeks ago #81196 by Patrick Obrien
andypugh wrote: I think that error is an actual bug.
Is there an external Test/Tune Axis app?
10 years 4 weeks ago #81197 by andypugh
Patrick Obrien wrote: Is there an external Test/Tune Axis app?
There are ways. With a stepper system the axes will either work with the final LinuxCNC config, or they wont.
10 years 3 weeks ago - 10 years 3 weeks ago #81262 by Patrick Obrien
andypugh wrote: There are ways. With a stepper system the axes will either work with the final LinuxCNC config, or they wont.
Perhaps I'll use stepconf, test the wiring, tune it a bit and transfer the values to pncconf. Unless the same bug exists there.
Last edit: 10 years 3 weeks ago by Patrick Obrien. Reason: add
10 years 3 weeks ago #81335 by andypugh
Patrick Obrien wrote: Perhaps I'll use stepconf, test the wiring, tune it a bit and transfer the values to pncconf.
That sounds like a reasonable approach. It reduces the number of unknowns.
