Starting over
10 years 2 weeks ago #81615 by PCW
Replied by PCW on topic Starting over
Right, so the errors are in the hal axis --> stepgen mapping
The G540 FPGA config is straight forward (stepgens 0,1,2,3 map into G540 axis X,Y,Z,A)
10 years 2 weeks ago #81618 by Patrick Obrien
Replied by Patrick Obrien on topic Starting over
PCW wrote: Right, so the errors are in the hal axis --> stepgen mapping
How can I verify I have the correct 5i25_g540x2.bit file?
cksum 5i25_g540x2.bit
3087903293 340704 5i25_g540x2.bit
sum 5i25_g540x2.bit
17348 333
10 years 2 weeks ago - 10 years 2 weeks ago #81621 by PCW
AFAIK, there are no incorrect 5i25_g540x2.bit bitfiles
( and your mesaflash readhmid listing shows the expected G540 compatible pinout )
As I said, the joint mapping error is in the HAL file
Last edit: 10 years 2 weeks ago by PCW.
10 years 2 weeks ago #81628 by Patrick Obrien
PCW wrote: As I said, the joint mapping error is in the HAL file
Thanks for that. I assumed since PNCCONF generated the file it was correct.
I did a simple test, I generated a XYZ config using PNCCONF and the axis work, X moves X ,etc. This tells me you are correct, the hal is off - it looks like a PNCCONF bug but probably a newbie snafu,
I did a diff of the two files, the XXYZ and the XYZ.
Using the XXYZ fundamentally shift the stepgen's. See the diff output enclosed.
Here is a sample:
setp hm2_5i25.0.stepgen.02.dirsetup [AXIS_1]DIRSETUP | setp hm2_5i25.0.stepgen.01.dirsetup [AXIS_1]DIRSETUP
10 years 2 weeks ago #81629 by PCW
Are you saying the pncconf config is in error (does not match what you selected)?
Normally a XYZ config to maps like this
X => 0
Y => 1
Z => 2
And I would expect a XXYZ config to map like this
Xa => 0
Xb => 1
Y => 2
Z => 3
but of course the mapping of axis to stepgens is arbitrary but the created hal file
should match what you select in pncconf
10 years 2 weeks ago #81644 by Patrick Obrien
PCW wrote: And I would expect a XXYZ config to map like this
Xa => 0
Xb => 1
Y => 2
Z => 3
Ok if that is the case (Y and Z shift one plus) then the HAL is correct. Ok more digging.
