I realize I could get my existing hardware working after I do endless edits and hammer the forum with questions while you teach me esoteric HAL programming but I'd rather swim with rather than against the tide.
PCW wrote: If this is for a G540 I would set the steplength on all axis to 2500 minimum (1000 will not work reliably)
If the axis are swapped that suggests that you are not using the proper FPGA configuration
andypugh wrote: How are you enjoying the journey upstream?
It just occurred to me that we haven't really done much to prove that it is easy. But I am hoping that you are at least enjoying the process?
See it as like skid-pan training. It's not an easy way to drive a car, but you learn a lot about the car.
PCW wrote: sudo mesaflash --device 5i25 --write 5i25_g540x2.bit
sudo mesaflash --device 5i25 --reload
