andypugh wrote: Because the pin allocation is set in firmware, and not HAL, it turns out that the HAL code is almost (and sometimes exactly) the same even if the firmware and physical pins change. So you can use the settings for a probotix breakout as long as your actual firmware is G540.
So, in PNCConf choose the 5i25 internal data and prob_rfx2 option (which is a simple dumb breakout). and choose "accept component changes"
Then configure connector 3. (which is the DB25 connector on the 5i25) and you will see "unused stepgens" numbered 0, 1, 2 and 3. Choose axes for these to suit how you want to wire the G540, for example 0 = X, 1 = tandem X, 2 = Y, 3 = Z.
I think that GPIO 000 is charge pump on the G540? If so then choose GPIO 000 as control-> charge-pump
This setup should be really very close:
andypugh wrote: You might want to consider switching to version 2.8 (not that Pncconf can do the tandem limit switch there either) but some elements of a gantry configuration are much simpler there.
andypugh wrote: (If you scan through the changes you might get some feel for how much better-suited for a gantry it now is)
linuxcnc.org/docs/devel/html/getting-sta..._configuration_files
