tommylight wrote: On a side note, so it does not continue to miss inform the public, G540 has NO micro stepping, it Has a delay (most probably a CD4017 CMOS), so it does nothing for 9 pulses. NOTHING. Wasted 2 days a while ago to figure that out.
They do mention that on the web, so it's all good, and they are perfect for hobby machines.
tommylight wrote: Did you wire the resistors on the motor connectors? You should, as without them it will run on full power even at a stand still. They need a 1kOhm per 1Amp of current, and even if you need full power, do add some 3.3Kohm to it.
I had 2 of them, still working without any issue, and never got to hot to act up, with no cooler or fan.
At what voltage are you powering it? I never used more than 32V for them on everyday use machines.
Patrick Obrien wrote: Please correct me! My logic is the rack (20 pitch 20 degree pressure angle) has 20 teeth on a one inch pinion.
