Biesse Rover 346 Retrofit
- Thank you received: 5337
21 Jan 2017 09:57 #86364
Replied by PCW on topic Biesse Rover 346 Retrofit
Thats strange, "hm2_7i77.02ac" means you _are_ using serial numbers
- bevins
- Thank you received: 338
21 Jan 2017 10:06 #86365
by bevins
I will try powering down the 7i77 and the computer and try it.
Replied by bevins on topic Biesse Rover 346 Retrofit
21 Jan 2017 10:07 - 21 Jan 2017 10:13 #86366
Its not related to the 7I77 or the computer... This is a driver setup issue
All sserial names are enumerated by sserial port and channel numbers if use_serial_number is false
so it should not be possible to have a name like "hm2_7i77.02ac" unless
use_serial_numbers is true
Last edit: 21 Jan 2017 10:13 by PCW.
- bevins
21 Jan 2017 10:14 - 21 Jan 2017 10:17 #86367
by bevins
Then if we only load one channel digital, and not the analog it should work properly?
Just for testing the theory.
Rebooting and power cycle the 7i77 my thoughts were some bit stuck, and that would fix it sio I can use it without use_serial_)numbers.
Last edit: 21 Jan 2017 10:17 by bevins.
21 Jan 2017 10:21 #86369
Nothing sticks on the 7I77
Everything should work properly if you truly have use_serial_numbers disabled
- bevins
22 Jan 2017 08:39 #86405
by bevins
Yup, no issue without use_serial_numers=1.
Thanks,
Bob
Thanks,
Bob
- Thank you received: 4656
22 Jan 2017 08:45 #86406
Sorry about the misleading advice, I wasn't aware of this quirk of the 7i77.
Replied by andypugh on topic Biesse Rover 346 Retrofit
- bevins
22 Jan 2017 08:58 #86407
by bevins
Hey no problem...... It was a fun detour.....
- bevins
24 Jan 2017 00:30 - 25 Jan 2017 09:18 #86535
by bevins
Connected power to the machine and powered up with the original control. WOW am I glad I am changing it......
Took a while but figured out to home the machine and jog the axis.
Youtube video
Youtube video
Last edit: 25 Jan 2017 09:18 by bevins.
- bevins
25 Jan 2017 09:14 - 25 Jan 2017 09:15 #86632
by bevins
Received my last shipment of Mesa Boards:
5i25, 7i77, 7i70, 7i71, 7i71, 7i84
All boards installed powered up and pins showing in Linuxcnc.....
Thanks Peter, Mesa Boards are great!!!!!!
Thanks John for your great service!!!!!!
The 7i70 is on the other side of panel where the inputs of the system are and not shown in this video.
Last edit: 25 Jan 2017 09:15 by bevins.
Time to create page: 0.302 seconds
