Z axis
6 years 4 months ago - 6 years 4 months ago #169752 by motal2004
Replied by motal2004 on topic Z axis
Alright so after taking a couple days off. I’m back
I started from a very beginning.
Installed a Linux mint 19.2 Linuxcnc Build , pulled from the forum.
I build my working base configuration.
Moved to plasmaC
I build my asxis plasmaC configuration and when inputting required information I selected mode 1.
Next I began the adding of the THCAD lines in the hal file. But also comments out everything pertaining to mode 1 and switch to mode 0. I Homed machine imputes my offset and scale info
Resting voltage is ready zero :)
Opened up imperial_squares.ngc file a
Set my plasma cuttter to 30 amp at 110 ipm
Cutting Voltage was was 93 ish on screen .
Made lots of progress, couple questions
Machine stop after first cut and got “valid arc lost program is pause”
What do I do for that?
Second I’m 1/16 of an inc , 1.5875mm , on the small size off I measure the cut square. Do I go up or down on the axis tunning?
Last edit: 6 years 4 months ago by motal2004.
6 years 4 months ago #169764 by phillc54
Replied by phillc54 on topic Z axis
Have you done some probe tests to confirm the heights are correct?
Could the size difference be due to kerf width?
6 years 4 months ago #169805 by motal2004
I took a quick peak this before leaving for work this morning at My machine torch, it appears it is kicked in just a little bit, I’m thinking that’s where I am loosing my 1/16 in my cuts I will try correcting that tonight.
As far as for probe testing, I did hit the probe test button before my cuts yesterday. This morning I jog the z axis all the way to the bottom, hitting the sheet metals, I jog up 1 inch on screen, measure physically and it’s 1 inch , jogged 2 inches on screen and physically re measure and I’m getting what seems to be consistent accurate measurements when jogging the z axis.
At lunch I’m going to do some re reading the manual again. I might be missing something.
Last think to me it appears that the GUI configuration of axis move slower then gmoccapy. Is that just in my head?
6 years 4 months ago #169883 by phillc54
Axis motion should be the same.
6 years 4 months ago #170182 by motal2004
For imperial_circle ngc or imperial_square.ngc
When I cutting it will cut the first part but when It moves to second cut I get error message of “valid arc lost program is paused”
Any suggestions?
6 years 4 months ago #170186 by tommylight
Replied by tommylight on topic Z axis
motal2004 wrote: For imperial_circle ngc or imperial_square.ngc
Any suggestions?
Video, and hal scope trace of arc voltage, what mode are you using ?
Time to create page: 0.382 seconds
