Build configurations from scratch in axis and gmocappy I get the same results .
PlasmaC mode 1
Ark ok wired in.
So below is a link to the video files I save . 1 video started test cut and it stops after first hole is cut out.
Second video , name arc ok disconnected “ is where I disconnected ark ok pin and torch cycles on 3 time before I get no arc detected error, my way of testing that I’m getting a signal to the correct pin location.
Video 3 is shows another attempt at cutting and with arc ok connected and what is show on the screen.
What else can i do?
Videos in file are not in order I label them should be easy to identify
drive.google.com/drive/folders/1kC6XCTTn...hyT01I3dVa-FV2GHv8h-
