Z axis
6 years 4 months ago - 6 years 4 months ago #170751 by motal2004
Replied by motal2004 on topic Z axis
Mode 0
voltage is reading correctly cutting at about 123V
on on my test part i has 7 cuts, 6 circles and the outside cut. i have to hit pause bottom to moved on to the next cut.
I have videos that i'm trying to figure out how to up load. here is a link to them for now,
drive.google.com/drive/folders/1kC6XCTTn...V2GHv8h-?usp=sharing
quality of video is not best , sorry
Last edit: 6 years 4 months ago by motal2004.
6 years 4 months ago - 6 years 4 months ago #170752 by phillc54
Replied by phillc54 on topic Z axis
Access is denied to the video.
I thought you had a machine with Arc OK out.
Last edit: 6 years 4 months ago by phillc54.
6 years 4 months ago #170836 by motal2004
Here’s the link again.
drive.google.com/drive/folders/1kC6XCTTn...hyT01I3dVa-FV2GHv8h-
Ya I’m going to make those connections tonight.
My Follow up Question to that is . My plasma machine has to outputs for “ok to move” do connect both those outputs to input in my Mesa 7i96 board?
6 years 4 months ago #170842 by bbsr_5a
Replied by bbsr_5a on topic Z axis
you can add this together as one
THCok signal and PlasmaOK signal to spindle-at-speed
loadrt and2 count=1 addf and2.0 servo-thread net thcok and2.0.in0 <= hm2_7i92.0.gpio.xxx.in net plasmaok and2.0.in1 <= hm2_7i92.0.gpio.xxx.in net readytomove and2.0.out => motion.spindle-at-speed
6 years 4 months ago #170846 by motal2004
bbsr_5a wrote: you can add this together as one
would i at this in the connection hal file?
6 years 4 months ago #170887 by phillc54
If you are using PlasmaC then the OK To Move would connect to your 7i96, something like:
net plasmac:arc-ok-in hm2_7i96.0.gpio.000.in => plasmac.arc-ok-in
in you <machine_name>_connections.hal and you would change the mode in the ini file to MODE = 1
