New Project with Mesa 7I96 and THCAD-05
5 years 4 months ago #211036 by rodw
It does not seem you have sorted out the buildbot commands discussed with Phill earlier in this thread. Linux does not know where to look for linuxcnc files.
5 years 4 months ago - 5 years 4 months ago #211038 by phillc54
Are you getting the latest version now when you run LinuxCNC?
Open Synaptic Package Manager, click Search at the top tight and enter linuxcnc as the search term. It should show all available linuxcnc packages.
Last edit: 5 years 4 months ago by phillc54.
5 years 4 months ago #211054 by TexasCNC
ok i had the rest of the packages unchecked and only did the 2 files that i edited. I was abe now to run that command here is what i got now:
carr@carr-pc:~$ sudo halcompile --install ohmic3.comp
[sudo] password for carr:
File "/usr/bin/halcompile", line 1512, in <module>
main()
File "/usr/bin/halcompile", line 1482, in main
process(f, mode, outfile)
File "/usr/bin/halcompile", line 1336, in process
a, b = parse(filename)
File "/usr/bin/halcompile", line 429, in parse
f = open(filename).read()
IOError: [Errno 2] No such file or directory: 'ohmic3.comp'
5 years 4 months ago #211055 by TexasCNC
does this mean that it installed?
5 years 4 months ago - 5 years 4 months ago #211069 by phillc54
It looks like it couldn't find ohmic.com
You probably need to be in the same directory as ohmic3.comp when you run halcompile or maybe enter the full path to ohmic3.comp
5 years 4 months ago #211128 by TexasCNC
Nope didn’t work tried putting the whole path and gave me a error. Is there a more easier way to install this? Got my z motor and did a cut and the thc still didn’t work. I checked all the setting ls and they all look correct my wiring to the cards are good. Going to put this Mesa setup aside and just buy a plug and play system. This stuff just takes up too much time trying to set it up. Will hook this up to my working machine later but for now I want the new table to be working will be buying a plug and play system. Thanks to the guys that replied to my issues and helped solve most of them I know the system works good and I thought it would work out for me but it’s just tough trying to learn all the Linux stuff and editing configs
Time to create page: 0.499 seconds
