New Project with Mesa 7I96 and THCAD-05
5 years 4 months ago #211202 by rodw
you might need to use sudo halcompile --install ./ohmic3.comp
Sometimes linux needs the "./" before a filename to tell it to look in the current directory
5 years 4 months ago - 5 years 4 months ago #212584 by acourtjester
I have tried to compile ohmic3 and it will not work I used both examples for the command line entry. I also have problems getting the key in the buildbot routing Phillc posted
Last edit: 5 years 4 months ago by acourtjester.
5 years 4 months ago #212594 by tommylight
Wrong folder, that has to be run on the folder where ohmic3 is located.
ASUS ROG Crosshair VIII Impact - AMD X570
5 years 4 months ago #212626 by acourtjester
I would be wonderful to know where the folder is.
And that is only one of the problems shown.
5 years 4 months ago #212628 by PCW
locate ohmic3
should help (assuming you are not running a RPI or other similar CPU)
5 years 4 months ago - 5 years 4 months ago #212630 by acourtjester
I am running a Dell optiplex, I just ran a find in the terminal and ohmic3 is not on this system.
Last edit: 5 years 4 months ago by acourtjester. Reason: ading info
Time to create page: 0.527 seconds
