New Project with Mesa 7I96 and THCAD-05
6 years 4 months ago #171693 by bbsr_5a
Replied by bbsr_5a on topic New Project with Mesa 7I96 and THCAD-05
pncconf has a full Setup Gui for the 7i96
6 years 4 months ago #171694 by TexasCNC
Replied by TexasCNC on topic New Project with Mesa 7I96 and THCAD-05
Yes I had set it up just basic with no inputs yet wanted to make sure I was able to open up the GUI as I was getting errors yesterday but figured it out. I want to make sure I can get signals to all my stepper drivers and motors once I build it on the kitchen table before I go in building table. I have a small table right now running 2.9 plasmac and it works awesome but connected to a chinese board with only 4 inputs so I was limited thats why I went with the mesa as it has more inputs and stuff. Then the THCAD cards also.
6 years 4 months ago #171777 by TexasCNC
Is there a reason why the axis GUI has button for lathe did I choose the wrong option for plasma?
6 years 4 months ago #171780 by tommylight
Replied by tommylight on topic New Project with Mesa 7I96 and THCAD-05
Where is it ?
On a side note, did you really have to set everything possible in the wizard ? You are running a plasma cutter, so flood, mist, bi-directional spindle, brake, are pretty much useless .
6 years 4 months ago - 6 years 4 months ago #171798 by TexasCNC
I need to go back into the Pncconfig wizard and disable those actions I didn’t see that. What would be the options for plasma that’s all I am going to use?
Last edit: 6 years 4 months ago by TexasCNC.
6 years 4 months ago #171813 by phillc54
Replied by phillc54 on topic New Project with Mesa 7I96 and THCAD-05
TexasCNC wrote: I need to go back into the Pncconfig wizard and disable those actions I didn’t see that. What would be the options for plasma that’s all I am going to use?
If you are using PlasmaC then the Configurator will handle all that later on, just put the minimum requirements to get a base machine working in Pcnconf.
Have a quick read of this section
Time to create page: 0.157 seconds
