- Thank you received: 4153
New Project with Mesa 7I96 and THCAD-05
TexasCNC wrote: Rod wouldn't I put the THCAD-10 in the control box rather than the plasma machine? And power up the THCAD ni the control box with its 5v power supply?
I would do it that way with the automation interface. I think without, I would send 5 volts back to the machine on 2 wires and have the frequency output on another two as it might be safer.
- phillc54
- Thank you received: 2100
Yeah, I mounted mine in the plasma machine, I don't want any chance of the full arc voltage coming into the panel. I sent 24VDC to the machine and used one of those cheap buck converters to trim it to 5V.rodw wrote:
- TexasCNC
- Thank you received: 10
- phillc54
You wouldn't need resistors and you could mount it in your control panel.TexasCNC wrote: How much easier would it be if I just bought the interface card for my machine? Would I need resistors and would I need to put the thcad in the plasma machine still?
phillc54 wrote: Yeah, I mounted mine in the plasma machine, I don't want any chance of the full arc voltage coming into the panel. I sent 24VDC to the machine and used one of those cheap buck converters to trim it to 5V.
Thats a better idea. Solves any voltage loss. I used one for my laser pointer.
- TexasCNC
