- Thank you received: 338
New Project with Mesa 7I96 and THCAD-05
- bevins
TexasCNC wrote: I have a 48v power supply for the drivers but the Mesa board is being powered by 5v as that’s what the board calls for. Now I been reading where you don’t need a relay for the outputs on the Mesa card? Also on the arc ok on my thermal dynamics CM52 I have cnc interface card and it has port 12 and 14 as the arc ok do I have to wire that to power as well with the ground wire going to the input?
That board uses 5v for logic power and up to 36 vdc for I/O. If your using 5vdc for plasma your just asking for trouble. Not sure a good idea to connect output directly to plasma cutter. If you dont understand both sides you could damage one or the other and possibly both. Jus fire a relay and give dry contact to plasma.... way easier and you isolate the two somewhat.
- TexasCNC
- Thank you received: 10
- bevins
Do what you want but a simple safeguard is to put a 20.00 relay. And that drawing is using 24vdc for I/O.
- Thank you received: 5334
1. "DRY CONTACT" to me means no voltage is applied
(and the 7I96 outputs apply no voltage, they are just switches)
2. Using the 7I96 output without a relay means it will be faster
and a relay may have a contact wetting issue with the quite small
15V @ a couple mA switched current.
- TexasCNC
- TexasCNC
