New Project with Mesa 7I96 and THCAD-05
5 years 5 months ago #208699 by TexasCNC
Yes I did that and tested it going 1 inch and it did go 1 inch but before it had a different number cause like said before I converted the pitch .5305 inc to mm and entered it on there and it was not right.
5 years 5 months ago #208700 by phillc54
It is best to use the same units rather than convert.
I "think" in the test page when you say one inch it acually move plus one inch then minus one inch so it is really twice the distance.
5 years 5 months ago #208701 by TexasCNC
Well at 848.8 it was moving 2 inches one way and 2 inches the other when I had to move only 1 inch so I cut in half on the steps and now it moves 1 inch one way and 1 inch the other way. But how do I know on the ini files that it took affect on the change I made?
5 years 5 months ago #208702 by phillc54
The value it has in "Stepper Scale" in the "Motor" pge in PnCconf should appear in the .ini file as [JOINT_n]STEP_SCALE
5 years 5 months ago #208704 by TexasCNC
Found it I changed it on the new configurator file it created and it still does not travel the 1 inch ask it to move. It goes 7.25 inches. Changed the stepper scale to the same I have on the wizard and where I test it and it moves 1 inch. Any other place I need to change it?
5 years 5 months ago #208705 by phillc54
No, that should do it.
Time to create page: 0.239 seconds
