New Project with Mesa 7I96 and THCAD-05
5 years 5 months ago #208706 by TexasCNC
Ok well I give up I might have to start all over again delete the plasmac machine and start with base and try it and hope it works not sure why they have mm in the calculation tab when you choose inches when your entering it on the first tab of the wizard.
5 years 5 months ago #208707 by phillc54
They have both mm/rev and TPI, you select the one you want with the checkbox on the left side.
5 years 5 months ago #208708 by TexasCNC
Yes I did do that when you mentioned it and I tested it and it was way off. I know the number I want to enter is right on as it working on my other machine same rack and pinion and motors. Only difference from that machine to this new one is the control board.
5 years 5 months ago #208709 by TexasCNC
I also tried to do the material from sheetcam to here and I was able to convert it and I open it .cfg file and I see where it entered my seetings but then I go into the GUI and load a project and it gives me a error that it can’t load cause it can’t find the material. I got it he panel where the material you can choose and hit the drop down and there is no material there.
5 years 5 months ago #208721 by tommylight
@TexasCNC,
Finger off the "report" button, please.
5 years 5 months ago #208728 by TexasCNC
Oops sorry been using the forum through my phone as my machine computer is not connected to the internet everything is small on the phone screen. Sorry about that
Time to create page: 0.446 seconds
