New Project with Mesa 7I96 and THCAD-05
5 years 5 months ago #208687 by TexasCNC
Also I was looking at my stepper settings and I am looking at my previous machine and I am using the same motors and drivers but on the pnc wizard it’s in mm and on the stepconfig wizard it’s in inches do I need to convert to mm? I did that and converted to mm but the test does not look to be traveling the distance it’s suppose to.
5 years 5 months ago #208688 by phillc54
When you use either wizard you need to set the units system to what you require. I think they both default to inch, so if you want metric you change it before you continue through the wizard.
5 years 5 months ago #208689 by TexasCNC
If I change it in the pncconfig right now will it change it on plasmac? Or do I need to start all over on the configurator?
5 years 5 months ago #208690 by phillc54
You can change it in pncconf only if you have not edited the machines .hal or .ini files. If you have run PlasmaC and it has built its default parameters based on the config then you will need to check ALL the parameters in PlasmaC to ensure that they are correct.
5 years 5 months ago #208691 by TexasCNC
So on the wizard even though it say mm for the pitch I put it in inches and it will automatically change it?
5 years 5 months ago #208692 by phillc54
if it is pncconf, on the "Base Information" page you will see below the machine name a box with either "Inch" or "mm" on it click it and select the units you want. All other entries are then done based on what you selected there.
Time to create page: 0.202 seconds
