- Thank you received: 338
New Project with Mesa 7I96 and THCAD-05
- bevins
5 years 5 months ago - 5 years 5 months ago #208360
by bevins
Arc ok looks like it is 12 and 14. It is a dry contact and that should be an input to the mesa board. Do it just like in the drawing.
Replied by bevins on topic New Project with Mesa 7I96 and THCAD-05
TexasCNC wrote: Any idea what I need to do here to hookup the arc ok do I need a power supply for it?
Last edit: 5 years 5 months ago by bevins.
- TexasCNC
- Thank you received: 10
5 years 5 months ago #208394
by TexasCNC
Replied by TexasCNC on topic New Project with Mesa 7I96 and THCAD-05
So I should be fine plugging one end to +24v and the to input pin?
- Thank you received: 7491
5 years 5 months ago #208415
Replied by tommylight on topic New Project with Mesa 7I96 and THCAD-05
Yes, if the schematics provided are correct.TexasCNC wrote: So I should be fine plugging one end to +24v and the to input pin?
- TexasCNC
5 years 5 months ago #208477
by TexasCNC
Ok let me try that and see if that works.
- TexasCNC
5 years 5 months ago #208684
by TexasCNC
Ok so I hooked up the relay and I tested it and I hear the relay click. I look at Mesa board and I see the led dim on the input and output ports and when I enable to the torch in I see the output pin led light up brighter. But on the float switch I am not seeing it light up on the GUI or in the Hal show. I see the led dim on the float switch port on board and when hit the float I see the led on board light up but not on my GUI. I flipped the wires and still the same thing. Do I need to invert the pin? This is the same thing on the breakaway switch.
- phillc54
- Thank you received: 2100
5 years 5 months ago #208686
by phillc54
Replied by phillc54 on topic New Project with Mesa 7I96 and THCAD-05
If the LED on the GUI is on normally then goes off when you trip the switch then the pin will need to be inverted.
Time to create page: 0.581 seconds
