New Project with Mesa 7I96 and THCAD-05
5 years 5 months ago #209821 by TexasCNC
PlasmaC 2.9
5 years 5 months ago #209865 by phillc54
It does work here:
5 years 5 months ago - 5 years 5 months ago #209938 by TexasCNC
Let me try that but how did you get a home all button I have to home each axis individually at a time?
Last edit: 5 years 5 months ago by TexasCNC.
5 years 5 months ago #209948 by TexasCNC
Well it wouldn’t work the way you have on your GUI so I just deleted the config and started again. And think it work now not sure yet once I home all axis and move the torch around then I try to home again all axis they don’t set to zero is there something different I need to do. This stuff just leads one thing to another and another. I followed the steps over and over again something new just keeps popping up that’s not working right I am still having issues with the arc ok led on the bottom of the GUI keep blinking every time I ground my lead to table from plasma and it was doing it with nothing hooked up to table when I was doing the probe test and float switch activated and the arc ok light kept going on and off.
5 years 5 months ago #209959 by phillc54
If you have HOME_SEQUENCE = <n> in all your [JOINT_n] sections then you will have a home all button.
Homing does not set zero, it only homes the selected axis (or all axes) you then need to TOUCHOFF for each axis, that will set zero.
I don't know why the LED would blink, did you try PCW's suggetions here
5 years 5 months ago #209963 by TexasCNC
I haven’t been trying to find an example on how to add the debounce. How would I do that?
Time to create page: 0.328 seconds
