New Project with Mesa 7I96 and THCAD-05
- phillc54
- Thank you received: 2100
23 May 2021 23:06 #209992
by phillc54
Replied by phillc54 on topic New Project with Mesa 7I96 and THCAD-05
Do you mean that if you disconnect the wire from 7i96 input 10 then the flashing stops?
Yes, to upgrade you would need to be connected or if you have a package install you could do it via a USB stick or similar.
- TexasCNC
- Thank you received: 10
23 May 2021 23:13 #209995
by TexasCNC
Replied by TexasCNC on topic New Project with Mesa 7I96 and THCAD-05
Yes when I disco the wire from pin 10 it stops.
- phillc54
23 May 2021 23:16 #209996
by phillc54
That seems to indicate it is caused by either the cable to your plasma power supply or the plasma power supply itself.
Does it show the same behaviour if you disconnect/connect at the plasma power supply?
- TexasCNC
23 May 2021 23:18 #209997
by TexasCNC
No it does with the plasma not powered on or ground clamp on my table.
What do I need to do now that I am on the internet on my computer?
- phillc54
23 May 2021 23:22 #209998
by phillc54
Sorry, I don't understand. Instead of disconnecting the wire at input 10, leave it connected and disconnect from the plasma cutter end.No it does with the plasma not powered on or ground clamp on my table.
If it its a package installation then in a terminal:What do I need to do now that I am on the internet on my computer?
sudo apt update
sudo apt dist-upgradePlease Log in or Create an account to join the conversation.
- TexasCNC
23 May 2021 23:26 #209999
by TexasCNC
Ok let me try that once the update finishes do I need to do anything linuxcnc after the update finishes?
- phillc54
23 May 2021 23:27 #210000
by phillc54
Just run LinuxCNC normally and it should fix it self up. It may shut down and say you need to restart, that is normal for some updates.
- TexasCNC
23 May 2021 23:40 #210002
by TexasCNC
What happens when it reaches to the “Configuring grub-pc”
- phillc54
23 May 2021 23:50 #210004
by phillc54
It may take a short time then continue.
- TexasCNC
23 May 2021 23:55 #210007
by TexasCNC
It asked to install it in 3 areas I think it only installed it 1 as the other 2 we’re giving errors but it’s complete now. Do I need to reboot? It didn’t ask me to.
Time to create page: 0.219 seconds
