New Project with Mesa 7I96 and THCAD-05
24 May 2021 00:23 #209959 by phillc54
Replied by phillc54 on topic New Project with Mesa 7I96 and THCAD-05
If you have HOME_SEQUENCE = <n> in all your [JOINT_n] sections then you will have a home all button.
Homing does not set zero, it only homes the selected axis (or all axes) you then need to TOUCHOFF for each axis, that will set zero.
I don't know why the LED would blink, did you try PCW's suggetions here
24 May 2021 00:50 #209963 by TexasCNC
Replied by TexasCNC on topic New Project with Mesa 7I96 and THCAD-05
I haven’t been trying to find an example on how to add the debounce. How would I do that?
24 May 2021 00:59 #209965 by phillc54
There "should" be debounce setup in the <machine>_connections.hal file already, check it out and if you are not sure post the file here.
24 May 2021 01:08 #209966 by TexasCNC
File Name: finalcnc_c...ions.hal
File Size:2 KB
24 May 2021 01:31 #209970 by phillc54
Give this one a try, you can change the value in this line if needed. Hopefully I got it right, it is untested.
setp   db_arc-ok.delay 5
24 May 2021 01:43 #209971 by TexasCNC
it gave me an error on starting up the gui
24 May 2021 01:44 #209972 by phillc54
What is the error?
24 May 2021 01:56 #209974 by TexasCNC
Dbounce: dlopen: /use/lib/linuxcnc/modules/dbounce.so: cannot open shared object
Twopass: load the modules cmd=<orig_loadrt dbounce names=db_arc-ok>
24 May 2021 02:00 #209976 by phillc54
Weird, I don't know what that means, maybe the different debounce components conflict.
Try this one instead.
24 May 2021 02:10 #209977 by TexasCNC
Error here is the full error
File Name: error.txt
File Size:4 KB
Time to create page: 0.210 seconds
