New Project with Mesa 7I96 and THCAD-05
24 May 2021 02:18 #209978 by phillc54
Replied by phillc54 on topic New Project with Mesa 7I96 and THCAD-05
That is an error with loading "dbounce".
The file I attached in my last post doesn't have "dbounce" in it, are you sure you copied the correct file?
24 May 2021 02:36 #209979 by TexasCNC
Replied by TexasCNC on topic New Project with Mesa 7I96 and THCAD-05
Let me check
24 May 2021 02:38 #209980 by phillc54
The error shown suggests that your machine doesn't have the dbounce component. It was pushed to master branch in September last year. What is the version number of PlasmaC shown in the Config Panel?
24 May 2021 02:44 #209981 by TexasCNC
Yes I copied the previous one. Now the new you sent works it loads up the GUI and i did put my torch down to material and activate the float and the arc ok and ohmic start to flicker still.
24 May 2021 02:49 - 24 May 2021 02:50 #209982 by TexasCNC
youtube.com/shorts/OYQXMVkKeqc?feature=share
This is what it’s doing no plasma connections connected
Last edit: 24 May 2021 02:50 by TexasCNC.
24 May 2021 03:28 #209984 by phillc54
Man that is weird...
Do you have [PLASMAC] MODE = 1 in the ini file?
The plasma cutter is powered off?
The flashing starts when the float switch is activated? If so, does it stop when the float switch is not activated?
Can you watch these pins while the flashing is happening?
halui.program.is-paused
halui.program.is-idle
halui.machine.is-on
plasmac.arc-ok-out
plasmac.arc_ok_in
24 May 2021 03:40 #209985 by TexasCNC
PlasmaC v0.134
I have it on Mode 1
the plasma is not even powered on at this moment
the flashing starts when the float is activated and when its not activated it turns off. But when I have my plasma on and i connect the ground lead its starts to flash as well.
24 May 2021 03:50 #209987 by TexasCNC
Halui. Paused is false
Halui. Idle is true
Halui. Machine on is false
plasmac.arc-ok-out is going true/false
plasmac.arc_ok_in is going true/false
24 May 2021 03:55 #209988 by phillc54
That is a fairly old version, June 9 2020. It would be worthwile updating, the latest is V191 Feb 22 2021. I shouldn't affect the issu you have but there have been a lot of improvements.
Do you have any values set in the Config Panel for Arc Voltage Scale and Arc Voltage Offset? If so can you see if the HAL pins plasmac.arc_voltage_offset and plasmac.arc-voltage-scale are the same as the Config Panel Settings.
Could you also post your complete config using the Backup button in the Config Panel.
24 May 2021 03:59 #209989 by TexasCNC
Yes I entered the scale and offset already. I flipped the wires on the input pin and still the same. I disco the input pin wire for the arc ok from board and I activate the float and it doesn’t do that flickering. It’s only when I hook up the wires to the board.
How would I update the version here on computer I currently don’t have it hooked to internet. Would I need to hook it up?
Time to create page: 0.199 seconds
