New Project with Mesa 7I96 and THCAD-05
5 years 5 months ago - 5 years 5 months ago #209982 by TexasCNC
youtube.com/shorts/OYQXMVkKeqc?feature=share
This is what it’s doing no plasma connections connected
Last edit: 5 years 5 months ago by TexasCNC.
5 years 5 months ago #209984 by phillc54
Man that is weird...
What is the version number of PlasmaC shown in the Config Panel?
Do you have [PLASMAC] MODE = 1 in the ini file?
The plasma cutter is powered off?
The flashing starts when the float switch is activated? If so, does it stop when the float switch is not activated?
Can you watch these pins while the flashing is happening?
halui.program.is-paused halui.program.is-idle halui.machine.is-on plasmac.arc-ok-out plasmac.arc_ok_in
5 years 5 months ago #209985 by TexasCNC
PlasmaC v0.134
I have it on Mode 1
the plasma is not even powered on at this moment
the flashing starts when the float is activated and when its not activated it turns off. But when I have my plasma on and i connect the ground lead its starts to flash as well.
5 years 5 months ago #209987 by TexasCNC
Halui. Paused is false
Halui. Idle is true
Halui. Machine on is false
plasmac.arc-ok-out is going true/false
plasmac.arc_ok_in is going true/false
5 years 5 months ago #209988 by phillc54
That is a fairly old version, June 9 2020. It would be worthwile updating, the latest is V191 Feb 22 2021. I shouldn't affect the issu you have but there have been a lot of improvements.
Do you have any values set in the Config Panel for Arc Voltage Scale and Arc Voltage Offset? If so can you see if the HAL pins plasmac.arc_voltage_offset and plasmac.arc-voltage-scale are the same as the Config Panel Settings.
Could you also post your complete config using the Backup button in the Config Panel.
5 years 5 months ago #209989 by TexasCNC
Yes I entered the scale and offset already. I flipped the wires on the input pin and still the same. I disco the input pin wire for the arc ok from board and I activate the float and it doesn’t do that flickering. It’s only when I hook up the wires to the board.
How would I update the version here on computer I currently don’t have it hooked to internet. Would I need to hook it up?
Time to create page: 0.099 seconds
