New Project with Mesa 7I96 and THCAD-05
5 years 5 months ago #210011 by TexasCNC
I checked all my connections on my plasma I installed a cnc interface bird and cable and all looks good all was plug and play. I disco the interface cable coming from plasma and the flickering stops I messed with the divider pins going from 16v to 30 to 50 with no change still was flickering. Not sure what it is I spent a lot of money on the interface board and cable that is meant to go with my machine.
5 years 5 months ago #210012 by phillc54
If you disconnect from the plasma cutter and the flicker stops then it must be coming from the plasma cutter. Is it possible that the wiring at the plasma cutter end is wrong.
5 years 5 months ago #210013 by TexasCNC
I did disco the torch cable and the flickering stopped and that was with the cable still connected to my plasma interface card.
5 years 5 months ago #210014 by phillc54
Wow that is odd. There seems to something wrong at the plasma cutter end then.
Check ALL the connections at the plasma cutter and also that the CNC interface card is wired in correctly.
5 years 5 months ago #210015 by TexasCNC
One thing I did notice that I was still able to fire my torch from the pulse button. If something was wrong with my arc ok wouldn’t that not let me fire the torch?
5 years 5 months ago #210016 by TexasCNC
Yes I did everything is plug and play I made sure all the sockets were pushed all the way in and the j2 twist on connector was inserted correctly there is only one way to inserted it.
Time to create page: 0.222 seconds
