- Thank you received: 10
I am confused, I thought we were talking about arc okTexasCNC wrote: The torch on pin is not flickering
I think you may need to check all your ground connections. I wouldn't think connecting the work lead should affect anything.I hook up the ground clamp to table and it starts flickering the float switch is not activated. Not sure what’s going on you think if I move to another pin and change it on the config
