New Project with Mesa 7I96 and THCAD-05
5 years 5 months ago #210222 by TexasCNC
Yes that’s how I have it wired but I am checking voltages and I have 24v on inputs on idle then when float switch gets activated it goes to 0v same with breakaway switch. On arc ok pin I have 24v. You telling me that the pins need to be seeing 0v and all my input pins? If so then I would need to see about my wiring but my float and breakaway are working fine I have the wires wired in a N/O state on switch for float and breakaway I have it wired in N/C state.
5 years 5 months ago - 5 years 5 months ago #210226 by PCW
I would have thought that ARC-OK (OK to move) was normally open
so you would expect to read 0V and the 7I96 input until the arc is established
Last edit: 5 years 5 months ago by PCW.
5 years 5 months ago #210229 by TexasCNC
Yes but I think what’s going on is that since it’s reading 24 volts already on all inputs port cause I checked with my meter my float switch and breakaway I need to switch the wires that way they read 0v and when the switch activates it will 24v. But why am I ready 24 volts and all ports though?
5 years 5 months ago #210230 by TexasCNC
This is the way I have it wired. I need to switch the wires on float and breakaway that way at idle they ready 0v an input pin. You think that’s the reason the arc pin is flickering?
5 years 5 months ago - 5 years 5 months ago #210235 by PCW
If input 10 of the 7I96 is at 24V without ARC OK present, there is a wiring error
possibly a missing ground
5 years 5 months ago #210301 by TexasCNC
I fixed the wiring on my switches for the inputs and now reading 0v at idle then when the float activated it reads 24v. I checked my arc ok cables and still getting the flickering I called TD again today and they said that 12 and 14 are just a dry contact and I did a continuity test on the wires and they all test out good. Something is up with the interface board or my plasma cause it’s just flickers when I hook up the ground clamp to table.
I am not looking at buying another interface board or plasma. The plasma works fine with the proma so I will be doing away with the Mesa boards and thcad-05 and thcad-10 i am sure they work great when working but didn’t work out for me cause of my equipment. So if anybody is interested in a Mesa 7i96 and 2 thcad cards let me know I willing to ship wherever.
Time to create page: 0.081 seconds
