New Project with Mesa 7I96 and THCAD-05
5 years 5 months ago #209965 by phillc54
There "should" be debounce setup in the <machine>_connections.hal file already, check it out and if you are not sure post the file here.
5 years 5 months ago #209966 by TexasCNC
File Name: finalcnc_c...ions.hal
File Size:1.66 KB
5 years 5 months ago #209970 by phillc54
Give this one a try, you can change the value in this line if needed. Hopefully I got it right, it is untested.
setp db_arc-ok.delay 5
5 years 5 months ago #209971 by TexasCNC
it gave me an error on starting up the gui
5 years 5 months ago #209972 by phillc54
What is the error?
5 years 5 months ago #209974 by TexasCNC
Dbounce: dlopen: /use/lib/linuxcnc/modules/dbounce.so: cannot open shared object
Twopass: load the modules cmd=<orig_loadrt dbounce names=db_arc-ok>
Time to create page: 0.367 seconds
