Boxford 125 lathe Tool Changer Comp FERROR (SOLVED)
- Thank you received: 2176
05 Nov 2020 12:32 - 05 Nov 2020 12:37 #188391
Replied by Aciera on topic Boxford 125 lathe Tool Changer Comp FERROR
Is this the comp I uploaded in my last post?
If not try that and see if it behaves any different. Remember with that one you need to declare the bare angles without the extra to clear the pawl (these should sum up to 90°) then you also need to define the extra and the locking moves as well. It's all described in the comp.
Last edit: 05 Nov 2020 12:37 by Aciera.
- Clive S
- Thank you received: 486
05 Nov 2020 14:25 - 05 Nov 2020 14:50 #188394
by Clive S
Ok are you in Ipswich by any chance ?
Ok just tried your comp it loads fine then command T2 it them moved forward but did not do a reverse and hung
So did not let me command another tool
Replied by Clive S on topic Boxford 125 lathe Tool Changer Comp FERROR
Last edit: 05 Nov 2020 14:50 by Clive S.
05 Nov 2020 14:53 #188395
No I'm not in Ipswich, I'm in switzerland but I'm sure Ipswich is nice too.
Strange I just compiled and ran the comp above and it works just fine in my setup.
Don't know whats wrong there.
What are your settings for the angles and the moves?
- Clive S
05 Nov 2020 14:56 #188396
by Clive S
I ran the comp as you sent it. I must have misunderstood.No I'm not in Ipswich, I'm in switzerland but I'm sure Ipswich is nice too.
05 Nov 2020 14:58 - 05 Nov 2020 15:02 #188397
It certainly should not have hung. But I guess we'll have to go back to the old one and work on that.
[edit]
HANG ON!! YOU NEED ANOTHER HAL CONNECTION FOR THAT ONE JUST A SEC...
[edit]
Last edit: 05 Nov 2020 15:02 by Aciera.
- Clive S
05 Nov 2020 15:01 #188399
by Clive S
I did not change any settings but I will try again with the angles to 40 to 45
05 Nov 2020 15:02 - 05 Nov 2020 15:05 #188400
Just a sec. Watch this space:
[edit]
Add this to your HAL:
net toolchanger-stepgen-fb <= stepgen.2.position-fb => toolchanger.stepgen-pos-fb
I'm sorry about that.
[edit]
Last edit: 05 Nov 2020 15:05 by Aciera.
- Clive S
05 Nov 2020 16:35 #188407
by Clive S
Seems to be a success . Thanks you have been a massive help. I will put it all back together and give it some more tests.
I don't think the jog is working. I will have to check tomorrow.
[edit]
05 Nov 2020 17:05 #188412
Great, make sure you also try to change across multiple steps. Like 3-2 or 2-8. Before you put everything back together.
- Clive S
05 Nov 2020 17:32 #188414
by Clive S
Time to create page: 0.496 seconds
