Boxford 125 lathe Tool Changer Comp FERROR (SOLVED)
- Thank you received: 2176
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 35000
setp stepgen.2.dirsetup 35000
that means you have a step length of 1 nanosecond and a step space of 0?
This is what mine look like:
# these are in nanoseconds
DIRSETUP = 2500
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
- Clive S
- Thank you received: 486
Another thing I find a bit strange are your stepgen settings:
DIRSETUP = 2500
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
I think the stepgens are correct 1& 0 are normal and mean something to Lcnc this is from stepconf my-mill
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 35000
setp stepgen.0.dirsetup 35000
Re the Adir
T2 False
T3 True
T4 F
T5 T
T6 T
T7 T
T8 F
T7 F went forward correct
T8 T
T6 F went reverse
T7 T forward
T8 F
T1 T
T3 T
T8 T
T6 F went reverse
T3 F went forward correct
T1 T
The tool numbers get mixed up to the actual tools ie. they end up out of sync
Thanks for your patience.
My files should open ok on any 2.8 version and don't need a machine connected as it a P/port. The above was done on the real machine
[edit]
Ok found this in the docs. Still not sure you got this setup right though,
(float) stepgen.<chan>.steplen - Length of a step pulse (step type 0 and 1) or minimum time in a given state (step types 2-14), in nano-seconds.
(float) stepgen.<chan>.stepspace - Minimum spacing between two step pulses (step types 0 and 1 only), in nano-seconds. Set to 0 to enable the stepgen doublefreq function. To use doublefreq the parport reset function must be enabled.parport.<p>.reset (funct) Waits until reset-time has elapsed since the associated write, then resets pins to values indicated by -out-invert and -out-invert settings. reset must be later in the same thread as write. 'If '-reset is TRUE, then the reset function will set the pin to the value of -out-invert. This can be used in conjunction with stepgenās doublefreq to produce one step per period. The stepgen stepspace for that pin must be set to 0 to enable doublefreq.Please Log in or Create an account to join the conversation.
- Clive S
So the Adir pin has no correlation to the actual rotation direction of the stepper?
[edit]
(float) stepgen.<chan>.steplen - Length of a step pulse (step type 0 and 1) or minimum time in a given state (step types 2-14), in nano-seconds. (float) stepgen.<chan>.stepspace - Minimum spacing between two step pulses (step types 0 and 1 only), in nano-seconds. Set to 0 to enable the stepgen doublefreq function. To use doublefreq the parport reset function must be enabled.
Ok for the avoidance of doubt I will hard code them in.
I set them to 20000 in the hal file. Unfortunately It made no difference
When it goes the wrong way I don't think it does the reverse move probably because it already going that way.
Anyway i installed it on my buster 2.8 and I am playing around with it.
I noticed that the "adir" signal sometimes gets reset to 0 at the end of a tool change but mostly not.
You mean that "toolchanger.currenttoolnumber" in halshow does not correspond to the commanded toolnumber or that the physical toolchanger does not move to the correct position?The tool numbers get mixed up to the actual tools ie. they end up out of sync
- Clive S
I guess I was barking up the wrong tree, sorry about that.
Yes. the physical turret get out of sync when it goes backwards. Then pressing T1 does not go back to its correct position.
From what I understand I think the toolchanger is controlled by the comp .the readme seems to say that it hijacks the stepgens.
I do not understand C or Python . I notice in the files the guy that did the comp left hhis email there but its an old file.
I suppose I could set up a stepper motor with a cardboard disc on it to act like the turret !!
[edit]
I wonder if this has something to do with this "fudge_factor"
position_req -= ((moves / divisor) + fudge_factor);
if(position_req < 0)
position_req += 360;
position_cmd = position_req;
progress_level = 3;
}Please Log in or Create an account to join the conversation.
- Clive S
I notice that the toolchanger.position-cmd for a specific tool shifts as I change tools. I would have expected that the respective tools position remains the same.
[edit]
{ position_req -= ((moves / divisor) + fudge_factor); if(position_req < 0) position_req += 360; position_cmd = position_req; progress_level = 3; }
I notice that in the side panel there is a jog control according to the docs it is only used to set the reverse to lock the turret by adjusting and then putting the setting numbers into the comp. The jog buttons for/back don't move the turret to the next tool it is only for getting the numbers in the comp correct.
- Clive S
There are no sensors on the turret so it has to move past the ratchet then reverse until the motor stalls.Ah, I was wondering what those Jogging buttons were for. The back jogging didn't seem to make any sense to me at all.
I gather you have seen that the odd numbers degrees are different than the even numbers.
Ie they are not at 45'
