Boxford 125 lathe Tool Changer Comp FERROR (SOLVED)
- rider-83
- Thank you received: 10
20 Aug 2021 15:15 #218243
by rider-83
Replied by rider-83 on topic Boxford 125 lathe Tool Changer Comp FERROR (SOLVED)
Found it.
Naughty jumper on the driver was set at FULL not HALF
- Turners
17 Sep 2022 21:22 #252204
by Turners
Replied by Turners on topic Boxford 125 lathe Tool Changer Comp FERROR (SOLVED)
Hi, will this work for the older version 2.7 I have a Boxford 160 tlc I'm struggling to set up any help would be appreciated ...
how do i get the tool turret to turn at the correct speeds
regards turners
regards turners
- Turners
18 Sep 2022 21:30 #252302
by Turners
i had tried this download but could not get it to load threw up errors
my files are this
my files are this
- Thank you received: 2176
19 Sep 2022 07:50 #252321
Replied by Aciera on topic Boxford 125 lathe Tool Changer Comp FERROR (SOLVED)
@Turners
Please don't double post, your issues are being dealt with in the other thread:
forum.linuxcnc.org/38-general-linuxcnc-q...teps?start=10#252320
- hitchhiker
30 Oct 2022 10:38 #255428
by hitchhiker
Replied by hitchhiker on topic Boxford 125 lathe Tool Changer Comp FERROR (SOLVED)
Hi !
I use your toolchanger.comp and get random erros.. if i restart linuxcnc then it works... if i restart then.. errors.. it hanging when make a toolchange or make a toolchange and doesnt lock back.
there are some differents in the comp files...
in the compfile from the 11/05case 3: // backward jog
if(position_cmd > position_req) // have we got there yet?
break;
if(bjog)
bjog = fjog = false;
progress_level = 5;
break;
in the compfile from 11/06
if(position_cmd < (stepgen_pos_fb - 0.00001)) // has the step generator reached the destination yet? - small number to compensate for pid error
break;
progress_level = 5;
break;there are some other changes... is it possible to explain to me.. a complete newbe... what this happend please?!
break;
if(bjog)
progress_level = 5;
break;
break;
progress_level = 5;
- Semsem23
02 Jan 2024 11:53 #289549
by Semsem23
Replied by Semsem23 on topic Boxford 125 lathe Tool Changer Comp FERROR
Hello ser . Im verry interested about the turret configuration. I have the same lathe controled with mach3 bob card . But I'm verry new in linuxcnc . Can you give me a hand with the turret configuration if you can pls .
Time to create page: 0.138 seconds
