Turret Rotating to fast and missing steps
18 Sep 2022 21:08 #252298 by Clive S
Replied by Clive S on topic Turret Rotating to fast and missing steps
my a xis in ini file?
66.76 ?
i have uploaded my files could you check I'm unsure where to change
what does this mean?
In theory unlinking the stepgen dir signal and using our own should work, but it didn't and the axis wanted to go backwards all
the time despite the flag being set at TRUE (FWD).    is it already unlinked in tool changer file.
thanks for you time
If the Boxford 160 is the same as the 125.
Then I would read the full thread from here
forum.linuxcnc.org/38-general-linuxcnc-q...error-solved?start=0
With help from "Aciera" and others we abandoned the A axis and used a comp.
This was using a p/port
The finished file are here
forum.linuxcnc.org/38-general-linuxcnc-q...ved?start=110#217847
www.youtube.com/shorts/iUaeWKeIqmM
www.youtube.com/shorts/TibpSsLeoEY
www.youtube.com/shorts/UaHC0L7MXGo
18 Sep 2022 21:08 #252300 by Turners
Replied by Turners on topic Turret Rotating to fast and missing steps
As this worked perfectly, I preserved my sanity and just left well alone.
to me this doesn't make sense. the toolchanger.comp is unlinked
so is my ini file
as what worked perfectly??
could anyone explain this statement
19 Sep 2022 07:47 - 19 Sep 2022 13:45 #252320 by Aciera
Replied by Aciera on topic Turret Rotating to fast and missing steps
Please don't post the same issues in different threads as that will just cause confusion for everyone. ie no double posting
So lets try and work through your issues here.
I think you are getting yourself confused. This is just a note from the person who wrote the toolchanger component to explain his approach.
Last edit: 19 Sep 2022 13:45 by Aciera. Reason: Deleted question about why you had 4 axis defined (used to be the way to set up a lathe config apparently)
19 Sep 2022 08:01 #252322 by Aciera
x axis moves but goes the wrong direction
In your ini file under [AXIS 0] change:
SCALE = 200.0
to
SCALE = -200.0
z axis doesn't now move but should go back to hard stop
Not sure what you mean with that. Do you mean it doesn't move when you try to home it?
I would advise to get the X and Z working properly before working on the toolchanger.
19 Sep 2022 08:13 - 19 Sep 2022 08:30 #252323 by Aciera
I see no settings for homing, does your machine not have home/limit  switches?
Just a note to avoid more confusion:
The configuration for the Boxford posted above by Clive S is for Linuxcnc version 2.8 , which is the current recommended version. You seem to be running an older version (2.7). A fair bit has changed with the update from 2.7 to 2.8, so copy/pasting from his config to yours will require more careful consideration than usual or it's likely to cause errors.
Personally I'd look at updating to 2.8 and then work with the config linked by Clive.
Last edit: 19 Sep 2022 08:30 by Aciera. Reason: added question about home/limit switches
The following user(s) said Thank You: tommylight, Clive S, Turners
19 Sep 2022 13:42 #252341 by Turners
hi i downloaded the latest 2.8
and made an iso. put disc it in the computer
i get an error:: this computer requires an x86-64 CPU but only detected an i686 cpu
unable to boot- please use a kernel appropriate for your CPU.
How do i find the correct iso???
thanks
19 Sep 2022 13:48 - 19 Sep 2022 13:53 #252342 by Aciera
I think you should be able to upgrade Linuxcnc 2.7 to 2.8 without changing the operating system.
edit:
It's just that most current iso images out there today require a 64bit machine and yours being older is 32bit
edit2:
for info on how to update Linuxcnc see section 5.1:
linuxcnc.org/docs/stable/pdf/LinuxCNC_Getting_Started.pdf
Last edit: 19 Sep 2022 13:53 by Aciera.
19 Sep 2022 18:15 #252359 by Turners
Hi guys thanks for all your help so far slowly getting there i have managed to do a fresh install of wheezy and upgraded linuxcnc to 2.8.3 for a fresh start.. alot to take in...
could anyone help me config the settings from Clive setup and delete the things i do not need?
Thanks again....
19 Sep 2022 20:22 #252364 by Clive S
Thanks again....
My setup was with a P/port  with an encoder A-B-Z for threading.  To thread with the 125 you have to use the tool at the back and use M4 (not M3)
so that it starts at the chuck and threads back away from the chuck .
It also has 2 home switches (X & Z).
Unfortunately I will be away for the next 2 weeks so cannot help.
The following user(s) said Thank You: Turners
20 Sep 2022 06:04 #252380 by Aciera
You will need to provide more information on your machine setup:
You are using the parallel port on the pc to communicate with the machine, right?
Are there any axis home/limit switches on the machine?
Do you have a signal from the spindle to measure the spindle speed?
Time to create page: 0.176 seconds
