Turret Rotating to fast and missing steps
20 Sep 2022 10:49 #252389 by Turners
Replied by Turners on topic Turret Rotating to fast and missing steps
its a parallel port on pc
there no home switches
i believe i have a signal to measure the spindle speed.
i have re install debian wheezy and upgraded to linux 2.8
at the moment i have toolchanger.comp not found  im curently getting
(sudo: halcompile: command not found) what am i now doing wrong??
20 Sep 2022 12:39 #252397 by tommylight
Replied by tommylight on topic Turret Rotating to fast and missing steps
To compile it requires the development version of LinuxCNC to be installed, but i have no clue how to get 2.8 dev on Wheezy, to long ago...
The following user(s) said Thank You: Turners
20 Sep 2022 12:52 - 20 Sep 2022 12:53 #252398 by Aciera
Last edit: 20 Sep 2022 12:53 by Aciera.
The following user(s) said Thank You: tommylight, Turners
20 Sep 2022 16:30 #252412 by Turners
i managed to update install 2.8.4
couldn't get them links to install
be looking all day
heres what i done i downloaded Clives/your boxford file put it all in Linuxcnc con-figs file clicked on file opened terminal
m@debian:~/linuxcnc/configs$ sudo halcompile --install toolchanger.comp
[sudo] password for m:
m@debian:~$ uname -r
3.4-9-rtai-686-pae
m@debian:~$ uname -v
#1 SMP PREEMPT Debian 3.4.55-4linuxcnc
any ideas now???
20 Sep 2022 17:26 - 20 Sep 2022 17:30 #252417 by Aciera
Replied by Aciera on topic Turret Rotating to fast and missing steps
Working with outdated hardware can be a bit of a pain.
The first link I posted should download a .deb file. That works for me.
Then you would need to install that .deb file:
www.tecmint.com/install-local-deb-packag...n-ubuntu-linux-mint/
edit:
If your pc has internet access you could also check the "package-manager" for the "linuxcnc-dev" package. Not sure if that still works on wheezy though.
Last edit: 20 Sep 2022 17:30 by Aciera.
20 Sep 2022 21:13 #252445 by Turners
thanks
had to reinstall installed to toolchanger.comp file the ran updates.
Now trying to just now see i i can run clives files to see if it starts up i still i get errors custom.hal missing
how do you copy and paste a debug file on Linux instead of typing it out?
21 Sep 2022 05:57 - 21 Sep 2022 06:02 #252475 by Aciera
In the "LinuxCNC Errors" window there should be a button in the lower right "Select All". You should then be able to copy/paste the content.
edit:
As for the missing "custom.hal":
In the Boxford.ini file under [HAL] section remove (or put a # in front of the line to comment it out)
HALFILE = custom.hal
There will likely be more errors to work through
Last edit: 21 Sep 2022 06:02 by Aciera.
23 Sep 2022 08:22 #252607 by Turners
morning
i have no copy and paste for some reason
i have create report file and close buttons only
i curently have ngc file not found: ngc tooolchange-54 Remap=m6 modalgroup=6 ngc=toolchange
note mav max 23.000 units/sec units/sec 1380.000 units/min
note ljog max23.000 units/sec 1380.000 units/min
note ljog default 15.000 units/sec 900.000 units/min
23 Sep 2022 08:37 - 23 Sep 2022 08:48 #252608 by Aciera
Might be better to start your config in a terminal window anyway:
$ linuxcnc
this should bring up the config selector window.
You should then be able to copy the error messages from the terminal window.
$ linuxcnc -l
ie minus lowercase letter L, should start linuxcnc with the configuration last used.
as for the ngc file not found:
In the Boxford.ini file under [RS274NGC] delete or comment out this line:
REMAP=M6 modalgroup=6 ngc=toolchange
edit:
Also since you don't have homing/limit switches on your machine change these lines in the Boxford.ini [JOINT_0] section:
HOME = 0
HOME_OFFSET = 0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_SEQUENCE = 0
and these in the [JOINT_1] section
HOME = 0
HOME_OFFSET = 0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_SEQUENCE = 1
The relevant documentation can be found here (section 6.13):
linuxcnc.org/docs/html/config/ini-homing.html
Last edit: 23 Sep 2022 08:48 by Aciera.
23 Sep 2022 09:42 #252611 by Turners
thank you guys for all your help so far !!!!
links and tips. !!
it loads up i have not connected to the machine yet how do i put back in the tool changer ngc file .
i also need to change my pins to suit my board.
i currently have
Found file(REL): ./Boxford.hal
No tool selected. Use M6Tx to set current tool
note: MAXV max: 23.000 units/sec 1380.000 units/min
note: LJOG max: 23.000 units/sec 1380.000 units/min
note: LJOG default: 15.000 units/sec 900.000 units/min
note: jog_order='ZX'
note: jog_invert=set()
task: 1612 cycles, min=0.000156, max=0.053974, avg=0.010242, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Time to create page: 0.801 seconds
