Boxford 125 lathe Tool Changer Comp FERROR (SOLVED)
- Thank you received: 2176
[KINS]
JOINTS = 3
KINEMATICS = trivkins coordinates=XZAto this
[KINS]
JOINTS = 2
KINEMATICS = trivkins coordinates=XZPlease Log in or Create an account to join the conversation.
- Clive S
- Thank you received: 486
In your INI. You need to change this
[KINS] JOINTS = 3 KINEMATICS = trivkins coordinates=XZA
to this
[KINS] JOINTS = 2 KINEMATICS = trivkins coordinates=XZ
Stupid me. I thought I had done that but edited the wrong ini file (bet you have never done that)
Now it works. How do I alter the velocity i.e. the equivalent of:
MAX_VELOCITY = 1 would this work setp stepgen.2.max_velocity 3
MAX_ACCELERATION = 5 setp stepgen.max_acceleration 5
Edit: Is this the correct place to reverse a bit more param rw float fudge_factor = 1 could I change that to 2.5?
I would think so. Try and report back.
NEVERedited the wrong ini file (bet you have never done that)
- Clive S
I will thanks
Sure, give it a try.
- Clive S
This worked
setp stepgen.2.maxaccel 50
setp stepgen.2.maxvel 20
I will try the fudge later (I am getting a bit cold)
- Clive S
This worked
Quick question I have noticed using the comp as it is now when it dose a tool move going forward then stops there is a small delay in the reverse move like 0.5sec. It did not do that when we used the A axis. Any clues?
[edit]
Ok now that I changed the maxaccel and maxvel for the stepgen I can see the problem in my simulated system as well.
Because the system has no feedback it just waits "long enough" for the forward move to finish before starting the backward locking move. Because you now sped things up by changing acceleration and velocity the forward move does not take as long as before so now there is some dead time where it doesn't move before going backwards.
The handle for this is the factor in (delay * 100). Don't let the comment (//Forward move) confuse you. Its actually the backward move.
Try maybe (delay_index < (delay * 75)) ) and recompile :
case 1: // Forward move
if(position_cmd < position_req) // have we got there yet?
break;
if(!fjog && (delay_index < (delay * 100)) ) // this figure depends upon the speed of the servo thread etc
delay_index++;Really it should just wait for the stepgen to reach the commanded position then it would be independent of set acceleration and velocity.
- Clive S
So it does the forward move, then stops for about 0.5s, then does the backwards locking move?
Or does it do the forward move then starts to go backward, stops for about 0.5s and then finishes the backward move?
]So it does the forward move, then stops for about 0.5s, then does the backwards locking move? Yes
