Building a chain driven Plasma table.
29 Jul 2021 05:34 #216206 by rodw
Replied by rodw on topic Building a chain driven Plasma table.
Stepper wires need to be 4 core shielded or you will guarantee countless hours chasing random issues
Don't forget to order the pins for those connectors. They are designed to be crimped and the tool is expensive.
You can also look at the Weipu SP-21 (12 pin) plugs and sockets. They come in sets.
I would get some 9 core shielded cable and use it for your sensor wiring etc and the CPC interconnect cable.
Cat 5/6 is not that robust.
The following user(s) said Thank You: Creative25
29 Jul 2021 06:15 #216210 by phillc54
Replied by phillc54 on topic Building a chain driven Plasma table.
Shielded motor wires is probably good practice.
Having said that I don't have shielded cables on any of my machines.
  • snowgoer540
  • snowgoer540's Avatar
  • Moderator
  • Moderator
29 Jul 2021 06:29 #216211 by snowgoer540
Replied by snowgoer540 on topic Building a chain driven Plasma table.
I made my CPC connecter cable from parts from Mouser here in the States. I used 22 Gauge 6 wire, 3 individually insulated pairs with overall insulation around the 3 insulated pairs. Probably unnecessary, but it's what I had on hand.
The pins are are designed to be crimped, but I soldered mine and squeezed the open end around the insulation a bit. That works perfectly fine, arguably a soldered connection is always better than a mechanical one.
Saved a bundle the CPC cord from Hypertherm is a bit pricey.
29 Jul 2021 06:48 #216213 by Creative25
Replied by Creative25 on topic Building a chain driven Plasma table.
In my case pins were already included.
08 Oct 2021 08:42 #222549 by Creative25
Currently I am Wiring up the control box.
I just upgraded to Linuxcnc 2.9 and use Qtplasmac.
Seems things are much more simple compared to Plasmac.
But no I am a bit confused.
So I updated firmware for the Mesa board 6i76e
Now how do I get The Thcad working?
I run the pncconfig. There are two firmwares I can choose from. 7i76e and one For 7i76e_7i76x1_Dpl
Which is the right one?
Or do I still have to manually edit some hal files?
08 Oct 2021 17:35 #222597 by andypugh
Replied by andypugh on topic Building a chain driven Plasma table.
It probably doesn't matter if you are just running the 7i76E with nothing on the expansion ports.
You might have to, but see how close you can get with the GUI configurator.
09 Oct 2021 05:19 #222628 by Creative25
The Configurator did make a hal file with entries for the thcad.
Is there I way that i can make the thcad show the voltage without connecting a plasma cutter?
  • Moderator
  • Moderator
09 Oct 2021 05:31 #222629 by tommylight
Replied by tommylight on topic Building a chain driven Plasma table.
Voltage is shown all the time, 0V if everything is set up properly when the torch is off.
If you have a THCAD5 or THCAD10, use a battery of 1.5 or 3 or 3,7 or 9V, it will show on screen but the value will be /scale.
09 Oct 2021 08:00 #222634 by Creative25
Thanks for the info.
If I connect a 1.5 volt battery i can see the Led on the Thcad blinks faster.
But on Qtplasmac it always shows Zero
I Attached the hal file that was generated by the Configurator.
File Name: PlasmaZaxis.hal
File Size:12 KB
File Name: PlasmaZaxis.ini
File Size:5 KB
  • Moderator
  • Moderator
09 Oct 2021 08:17 #222636 by tommylight
Screenshot of preferences?
Time to create page: 0.347 seconds
