Emergency STOP on mesa card 7i76e
- bevins
- Thank you received: 338
I don't think that is a good idea for one reason is you can override the limit switch with one click of a mouse. With an estop you should not be able to operate unless you have cleared the fault, not click a checkbox.Good evening everyone,
Saying so my first thought is to wire the Emergency button in parallel with one of the limit switch.
Regards,
V.
- arvidb
- Thank you received: 158
Certification standards have been paid for with blood: accidents happen and then people figure out the standards needed to avoid them in the future. Safety relays have been shown to work with rigorous testing, and have redundancy. Can you say the same for your homebuilt circuit?Well, my opinion is safety relays are overrated. They are just inputs and relays and microprocessors that is certified to work? Really?
This is exactly the same thinking that recently killed 14 people in a cable car in Italy . "I've worked with cable cars for 30 years and I've never seen a pull cable break, therefore I can disable both of the redundant emergency brakes instead of fixing them."I don't know about you but I have worked on many machines built from scratch and retrofits and I have never had a relay fail or an estop circuit fail.
That said, I agree with you that if you have a hobby machine that cannot hurt you seriously then safety relays might be overkill.
- bevins
Inside safety relays are inputs firing a relay if the inputs are clean. Some have microprocessors that can have logic failure. Explain how this is different than having an input energize a relay.
This is exactly the same thinking that recently killed 14 people in a cable car in Italy. "I've worked with cable cars for 30 years and I've never seen a pull cable break, therefore I can disable both of the redundant emergency brakes instead of fixing them."
- scotth
- Thank you received: 61
- Thank you received: 7465
- bevins
Absolutely I can say my circuits is the exact same thing as the Siemens and many other safety relays. There is no redundancy built into them whatso ever. Inputs firing outputs. That's all they are. just look at the schematics of a few. I dont know about the ones you are using but the ones that are used mostly in CNC are named safety relays because it is used in the safety circuit. Not because it has any extra safety features. Just look at the schematics.
You are being a bit over exaggerating comparing a life safety equipment that deals with humans than a 10 lbs gantry hobby machine.
just my 2 cents...
- Thank you received: 4141
The thing your relay circuit does not have is certification under EN ISO 13849-1, or EN 62061
There were 4 deaths near me because the estop was not pressed.... and safety features were removed and/or disabled.
www.bbc.com/news/world-australia-54321389
There is a big difference in a home machine but if you were building a machine for sale I guess it depends upon your risk appetite for litigation and criminal proceedings....
- JohnnyCNC
- Thank you received: 115
In parallel would imply that you are using normally open switches. It is much safer to use normally closed switches. In the case of a broken wire or bad switch you will find the problem before the switch is needed. With NC switches you would wire all of the limit switches in series.
- arvidb
This is the kind I'm talking about: Safety relay ABB RT9 . You can find them from other manufacturers too. They have redundant, short-circuit monitored "input circuits" (i.e. two circuits through emergency stop buttons etc) and also redundant outputs so that you can have two contactors in series to cut the power. They can also monitor the contactors for welded/stuck contacts though the contactors' auxiliary contacts.
I'm assuming this is the type of relay rodw was talking about earlier in the thread as well, considering he said he paid 250 $AUD for one!
There's no need to resort to trolling...
- sibelius
- Visitor
This is a simple drawing of the wiring that I have in mind.
I hope you can read it.
I connected the Enable + and Enable - to the NO side of the Emergency button because in normal conditions (when they are not connected like at the present moment), the driver that control the stepper is Enable, so what I expect when I press the button is to close the circuit and consequently Disable the driver.
The other NC side of the button would be wired on the DC side of the driver power supply or maybe on the AC side.
If this is ok next step is to generate the signal to implement my hal file.
Thanks in advance for any help.
