Emergency STOP on mesa card 7i76e
- Sray69
- Thank you received: 13
14 Nov 2022 16:40 #256701
by Sray69
Replied by Sray69 on topic Emergency STOP on mesa card 7i76e
Perfect! Thanks!
- Sray69
14 Nov 2022 17:03 #256702
by Sray69
Just so I understand how this setup will work, when I hit the E-stop button it will kill power to the drives, disable the drivers, and provide a fault signal that can be used in LinuxCNC?
From what I can tell, once the E-stop is reset the motor and drives will come back on. What about the fault in LCNC? Will I need to reset it on-screen before the machine can run? Would I be able to resume my job or would I have to start over?
- Thank you received: 7465
14 Nov 2022 19:27 #256711
You can resume the job with "run from here", just beware it can not continue on arcs, only straight lines.
Replied by tommylight on topic Emergency STOP on mesa card 7i76e
No, it wi reset itself if it is wired to an input and in hal to estop-ext.. What about the fault in LCNC? Will I need to reset it on-screen before the machine can run? Would I be able to resume my job or would I have to start over?
The following user(s) said Thank You: Sray69
- Sray69
14 Nov 2022 19:34 #256712
by Sray69
I believe I understand. Thanks!
- Sray69
14 Nov 2022 22:00 #256730
by Sray69
So I started laying things out and came up with a question. I plan to have 2 E-stops on the machine since it is kind of big. By looking at the diagram I am going to need to run both 120V and 24V cables to the E-stops and back to the cabinet?
I assume I can just daisy chain the buttons so I don't have to run separate lines?
- scotth
- Thank you received: 61
14 Nov 2022 22:53 #256738
by scotth
Replied by scotth on topic Emergency STOP on mesa card 7i76e
Series the NC contacts. Parallel the NO contacts.
Any break in the NC string should kill the power to all drives and solenoids.
The NO string should be the input to the CNC control.
- Thank you received: 4141
15 Nov 2022 00:07 #256744
Replied by rodw on topic Emergency STOP on mesa card 7i76e
Its not well documented but if you don't want to run mains power all over the place, you can use the estop-latch component to build your estop chain in hal..
- Sray69
15 Nov 2022 03:51 #256750
by Sray69
I guess I hadn't thought about it enough to realize I would need to run mains to all the E-stops. I may visit the E-stop Latch component down the road some. I finally got my head wrapped around (somewhat) the E-stop circuit. I can't afford to get tripped up for another couple weeks on this. Thanks for informing me though.Its not well documented but if you don't want to run mains power all over the place, you can use the estop-latch component to build your estop chain in hal..
- Sray69
15 Nov 2022 03:52 #256751
by Sray69
Thanks for the info. Very helpful!Series the NC contacts. Parallel the NO contacts.
- Sray69
15 Nov 2022 15:38 #256777
by Sray69
Just want to make sure I understood correctly. Is this the correct way to run multiple E-stops?
drive.google.com/file/d/1bnyHYjIujx_4SGP...8jA/view?usp=sharing
Time to create page: 0.134 seconds
