7i76e
4 years 9 months ago #231207 by Aldenflorio
7i76e was created by Aldenflorio
Hello, I’m trying to set up and configure my 7i76e board. I built a plasma before, though I used a 7i96 board instead. I forget since what exactly to do. I am not fully sure where to set all the pins, how to configure the board to 10.10.10.10 or 10.10.10.1 or which ever. I’ve got the set up otherwise. I just forget these things
4 years 9 months ago #231210 by Aldenflorio
Replied by Aldenflorio on topic 7i76e
I’m confused by that reply
4 years 9 months ago #231211 by tommylight
Replied by tommylight on topic 7i76e
The same question was there about powering 7i76E.
For the rest leave everything factory set, only change the IP address jumper if you want but it is not required, it will work also with factory set at 192.168.1.121.
4 years 9 months ago #231328 by Aldenflorio
I figured it out. I just had to change the ip in pfthing
i am now encountering another issue though. My motors are not moving. They are only lightly buzzing. I have double triple and quadruple checked that all the pins were set up correctly based on the motors manual. Though they still face this issue. How do I test to see which white actually goes to which one? I don’t want to fry the motors
My motors:
cutt.ly/GfrJ5DD
4 years 9 months ago #231357 by tommylight
Are they buzzing when jogging or when standing still?
If they buzz when jogging,
-set the step time and step space in hal/ini/pncconf higher, at least 5000 for both
-check the drives at what current they are set
-lower the jog speed a lot in GUI and try jogging again.
Time to create page: 0.283 seconds
