7i76e
4 years 9 months ago #232220 by rodw
Replied by rodw on topic 7i76e
I think there was a lot of mud in the water before I got here.
Ok, the drive in use is the V 4 version in this manual (with 5v/24v switch)
www.omc-stepperonline.com/download/DM542T_V4.0.pdf
The correct wiring is shown in Figure 4 in section 4.1 exactly as I said earlier.
The existing steplen parameters should be fine for a DM542. My config used 500,500,2500,2500 with them so I do not expect the change to 5000 will have any affect.
There are some very  low max velocities set in the ini file 4 ipm??? Get these up to a more reasonable value. say 400-500 rpm (my DM542s could do 750 rpm
Back to basics
Next question: Do you have holding torque with the motor powered up?
If not follow Tommys advice.
4 years 9 months ago #232245 by rodw
Hmm, this may be an incompatibility with the mesa 7i76e and the DM542T (V4) driver from Steppersonline.
Read this:
forum.linuxcnc.org/9-installing-linuxcnc...xes-fail-to-function
Maybe its a PCW issue.
4 years 9 months ago #232267 by Clive S
Replied by Clive S on topic 7i76e
Read this:
Finally you are listening ! In the op's case, the one I am working with. linked me to the wrong drives ie DM556
and did not tell me he had changed the drives.
I now have his config working
In ini file Display
MAX_LINEAR_VELOCITY = 1.000000 changed to 20
in X axis
MAX_VELOCITY = 4.33333333333 changed to 15
MAX_ACCELERATION = 30.0
Joint 0
STEPGEN_MAXVEL = 5.42 changed to 20
STEPGEN_MAXACCEL = 37.50
I would also change. It dose not do any harm
DIRSETUP = 2500 to 5000
DIRHOLD = 2500 to 5000
In the Y axis I had to remove the -sign from HOME_SEQUENCE = -1 in both joints
This is so I could jog the X axis (as with the -sign you have to home the machine first before it will jog)
So only test this with the X axis or the gantry will rack
This is working with single ended. If it works then you can try differential and see if it is ok.
4 years 9 months ago #232290 by rodw
Clive, do you have the same drive? I did not realise that.
I don't like using single ended when it can be done just using step and dir pins because it obfuscates things in my view. Simple is good.
4 years 9 months ago #232298 by Clive S
Yes I always use differential when I can but it does not always work then you have to do it single ended.
Not all bobs will take differential .
4 years 9 months ago - 4 years 9 months ago #232301 by Clive S
File Name: plasma_Table_G.zip
File Size:7.16 KB
www.omc-stepperonline.com/digital-steppe...t.html?search=dm542t
Ok back on track please see forum.linuxcnc.org/38-general-linuxcnc-q...i76e?start=70#232267
To be safe unplug the drives from the gantry axis so that it won't rack
then follow the instructions re: removing the minus sign from the two joints
I have it working here :) From now on you have to hand edit the hal and ini files
Last edit: 4 years 9 months ago by Clive S.
Time to create page: 0.063 seconds
