7i76e
- Aldenflorio
- Thank you received: 15
16 Jan 2022 11:51 - 16 Jan 2022 11:52 #232037
by Aldenflorio
Replied by Aldenflorio on topic 7i76e
imgur.com/a/OEw8NnZ
this is a video of my box. I don’t have a 5v power supply, I only have 2 48v power supplies and two 12v power supplies. I tried, nonetheless, only connecting one of the dir and step pairs. This didn’t do anything. I keep looking for specs on the motors I bought but they are seeming hard to find. Im not using the enable pins. As far as I thought as long as they aren’t in then the drivers are always enabled. Again I don’t have a 5v power supply. Should I get one? I’ll try inverting them but I don’t think that will do anything either. I shall try though
im over this and am willing to buy all new drivers if I could just wire them up the way I have my current ones wired up. Are there any someone could point me to. From Amazon hopefully
Last edit: 16 Jan 2022 11:52 by Aldenflorio.
- Aldenflorio
16 Jan 2022 12:05 #232039
by Aldenflorio
Screw it, I’m buying all new drivers that I know will work. I tried to upgrade this time but I’m over it
- Clive S
- Thank you received: 486
- Thank you received: 4154
16 Jan 2022 13:25 - 16 Jan 2022 13:28 #232050
Replied by rodw on topic 7i76e
There is no need for a 5 v power supply as Clive has said. Just set the jumpers
See my 7i76e video
Those are good drives, don't throw them out.
See my 7i76e video
Last edit: 16 Jan 2022 13:28 by rodw.
- Aldenflorio
16 Jan 2022 13:32 #232052
by Aldenflorio
I’m sorry, but I’m not quite sure where the misinterpretation is coming from. I am not trying to come off sassy or with an attitude. I am just frustrated with my situation and I know these motors I mentioned. I don’t know the ones I bought for this new table.
My drivers are being powered by the 48v power supplies, they are set to give out 30v.
I tried what you said Clive S, I just don’t have a 5v power supply so I’m not sure where the 5v is suppose to come from. I’m sorry I seem snippy to you.
im just frustrated with my situation.
I’ll watch your video again Rodw, I found some parts confounding but I’ll do my best to follow along. I though all my jumpers were suppose to be set to default
- Clive S
16 Jan 2022 13:49 - 16 Jan 2022 13:51 #232054
by Clive S
Replied by Clive S on topic 7i76e
Please show what power supply is connected to the 7I76e where it is connected you can get the 5V from the card
Can you sketch how you have connected the drive to the mesa card (forget the motor connections) just do a drawing and take a pic with the phone and upload
Last edit: 16 Jan 2022 13:51 by Clive S.
16 Jan 2022 14:07 #232057
In my video I refer to Norberts "My 7i76e connection sheet" That covers the connections. (As does the mesa manual)
- Aldenflorio
16 Jan 2022 14:25 #232061
by Aldenflorio
- Aldenflorio
16 Jan 2022 14:46 #232063
by Aldenflorio
- Clive S
16 Jan 2022 16:00 #232069
by Clive S
You are still wiring as differential. You need to wire it as single ended input like the link I posted.
forum.linuxcnc.org/38-general-linuxcnc-q...i76e?start=20#231759
Closely look at the driver wiring
You need 5v from the mesa card have you checked the jumpers on the card.?
Time to create page: 0.389 seconds
