7i76e
- Clive S
- Thank you received: 486
13 Jan 2022 16:54 #231713
by Clive S
Replied by Clive S on topic 7i76e
How are you trying to move the motors ? Have you homed the machine ?
Can you show a wiring diagram of exactly how you have connected the 7i76e to the drives ?
- Aldenflorio
- Thank you received: 15
13 Jan 2022 17:19 #231717
by Aldenflorio
Replied by Aldenflorio on topic 7i76e
I have all the homing switches set up and they are all properly assigned. When I open Linuxcnc for the table they even respond when being pushed on (the limit switches that is). i am using the limit switches as homes as well. you'll be able to seed that in my hal and ini files i believe. I am trying to move the motors on the test section of the Pfcon setup and i am trying to move them from Linuxcnc.
My motors are wired this way:
1 - From motor to aviation connector
2 - From aviation connector to driver as the pins are said to be on the site I bought the motors from (P1 A+, P2 A-, P3 B+, P4 B-)
3 - From driver to 7i96e board: Pul- to step- or pin2 ______ Pul+ to step+ or pin3_______ Dir- to Dir- or pin4_______Dir+ to Dir+ or pin5 (pin1 & pin6 are unused) (this pattern is repeater except for the Z motor because its a different motor)
- Clive S
14 Jan 2022 02:03 #231735
by Clive S
Have you read the manual ?
From the manual:-
STEP/DIR INTERFACE
The 7I76E provides five channels of step/dir interface with buffered 5V differential
signal pairs. Each differential pair consists of two complementary 5V outputs. The
differential signals allows reliable signal transmission in noisy environments and can
directly interface with RS-422 line receivers. Step motor drives with single ended inputs
connect to just one of the STEP and DIR signal outputs, that is either the STEP+/DIR+ or
STEP-/DIR- signals, with the unused signals left unconnected at the 7I76E. The input
common signal on drives with single ended inputs connects to the 7I76Es GND or 5VP
pins depending on the drive type.
The the drives you have are single ended so in my opinion you have them wrongly connected as differential so will never work.
From the manual:-
STEP/DIR INTERFACE
- Aldenflorio
14 Jan 2022 05:12 #231743
by Aldenflorio
What? Yes I read the manual and I actually built one before. Everything electronically remains the same except for the board. I built my last one with a 7i96 board. These drivers worked for that build. So what you’re suggestion is that I have then the wrong drivers entirely? Or are you suggesting that I need to disconnect one the step/dir pairs? I’ll try that but I’m not sure that will do anything.
What about these drivers? STEPPERONLINE CNC Stepper Motor Driver 1.0-4.2A 20-50VDC 1/128 Micro-Step Resolutions for Nema 17 and 23 Stepper Motor www.amazon.com/dp/B06Y5VPSFN/ref=cm_sw_r..._encoding=UTF8&psc=1
- Clive S
14 Jan 2022 07:12 #231753
by Clive S
Why the attitude? I did not say that you have the wrong drives your drive are single ended.
Do you understand this part of the manual:
STEP-/DIR- signals,
STEP-/DIR- signals,
- Aldenflorio
14 Jan 2022 07:31 #231756
by Aldenflorio
I’m sorry, though I didn’t intend for that passage to come across as a me having an attitude. I don’t have one. I was just unsure about what you were saying.
I believe I understand that, it’s saying that if I have a single input driver then I should only connect a single pair of dir and step, either + or -. Along with that it sounds like you’re also saying I need to connect the GND and 5VP potentially. What is my drive type and how do I figure that out?
- Clive S
14 Jan 2022 07:51 - 14 Jan 2022 08:04 #231759
by Clive S
Last edit: 14 Jan 2022 08:04 by Clive S.
- Thank you received: 4154
14 Jan 2022 15:39 #231805
Replied by rodw on topic 7i76e
Don't over think it. just wire step+ and step - on the mesa card to pul+ and pul- pins on the drive and do the same for direction.
Some of the docs in drives like this are for systems with active low outputs and don't apply to the 7i76e
I have used similar DM542 drives this way.
- mikeross
- Thank you received: 3
14 Jan 2022 22:25 #231858
by mikeross
Replied by mikeross on topic 7i76e
If you have the enable wires connected try disconnecting them and seeing if it works, or invert the logic in your hal file on the enable signal.
- mikeross
14 Jan 2022 22:46 #231860
by mikeross
BTW - your motors are possibly going to draw too much current for those drives, if the motor is rated 5A and the drive is 5.6A Peak (4.0A RMS) - at the very least the drives are going to get hot.
I'm not sure what other behavior the drives may exhibit when connected to a load higher than it can handle....it may go into an overcurrent shut down - hence your buzzing.
Time to create page: 0.285 seconds
