7i76e
- Aldenflorio
- Thank you received: 15
17 Jan 2022 11:50 #232143
by Aldenflorio
Replied by Aldenflorio on topic 7i76e
I did this. There was no change in the motors behavior. It’s still not doing anything
- Clive S
- Thank you received: 486
17 Jan 2022 11:56 #232145
by Clive S
Saying the above does not help !!!
Did you change the drive switches ?
Make a sketch again and show what you have done.
I did setup a config and tested this out for you.
Replied by Clive S on topic 7i76e
- Aldenflorio
17 Jan 2022 12:02 - 17 Jan 2022 12:03 #232147
by Aldenflorio
I don’t know what else to say, I changed the wiring like you said. I’ll draw a picture up. Im not getting error messages, im not getting anything. I try test/tune and when I run them the numbers change but the motors don’t do anythingthe box that says new is my new wiring
i even used a new DM542T driver. It didn’t change the motors behavior. So the drivers aren’t shot
Last edit: 17 Jan 2022 12:03 by Aldenflorio.
- Aldenflorio
17 Jan 2022 12:16 #232150
by Aldenflorio
WAIT!!! We have SOME movement
- Clive S
17 Jan 2022 12:17 #232151
by Clive S
Have you changed the drive switches !!!!
This is a config for a lathe just for test it is setup for ip 10.10.10.10
and only for the X axis
- Aldenflorio
17 Jan 2022 12:18 #232152
by Aldenflorio
So I was reading the manual more and I saw that there the 24v or 5v on the drivers as a switch. I switched it and now the X is jittering! It’s not moving properly but it’s jittering! That’s an improvement lol. I’m going to go back and retry all the suggestions for stuff
- Clive S
17 Jan 2022 12:24 - 17 Jan 2022 12:26 #232153
by Clive S
???? please explain
I have put a link to a config above .
If you don't answer question I can't help
???? please explain
Last edit: 17 Jan 2022 12:26 by Clive S.
- Aldenflorio
17 Jan 2022 12:34 #232154
by Aldenflorio
Okay, so nothing changed but the only difference I made. Was the switch on the driver. I’m sorry. I’m trying. I’m doing this on my mobile so I have to hook my computer up to the internet Ethernet to try out your config
- Clive S
17 Jan 2022 12:43 #232156
by Clive S
What switch on the drive !!!!!!!!!
Please read your posts and see if they make sense as to what you are saying.
Did you set the switches on the drive that I linked to.
If you want to try the config copy it to a usb stick.
If you don't answer questions then I give up.
- Aldenflorio
17 Jan 2022 12:50 #232159
by Aldenflorio
I changed this switch. From 24v to 5v. This caused the motors to be able to jog. Why are you getting frustrated with me? I am trying. I’ve thanked you so many times for your time. I don’t know how to respond better. I’m trying to get your configuration working for me but it won’t let me toggle the e-stop. I’m TRYING.
im looking for what you said you linked to me and I did everything you suggested. I don’t know what you mean as linked to me
Time to create page: 0.397 seconds
