7i76e
- Aldenflorio
- Thank you received: 15
16 Jan 2022 16:09 #232071
by Aldenflorio
Replied by Aldenflorio on topic 7i76e
That’s what I had previously. I’m not sure where to exactly get the 5v from. Not which jumper to change. I’ll read further and keep trying to see what jumper and where to get it from
does that diagram say to get the 5v from the driver?
- Clive S
- Thank you received: 486
16 Jan 2022 17:35 #232082
by Clive S
From the manual:
LOGIC SECTION POWER
The 7I76E can get its 5V Ethernet, encoder, step/dir and serial interface power from
connector P3 or the on card logic power regulator can be used with unregulated DC power
supplied to TB3. When the on card regulator is used, the maximum power available from
the encoder, serial, and 26 pin expansion connectors is 2A total. If isolation of field power
and logic power is not required, a common 8 to 32VDC power supply can be used for all
7I76E power.
Or TB2 on the card Please see page 14 of the manual
From the manual:
TB2 PIN SIGNAL
1 GND
2 STEP0-
3 STEP0+
4 DIR0-
5 DIR0+
6 +5V THIS IS 5 VOLTS
Do you have a meter if so measure pin 1 to pin 6 you should get 5V
Look at Rods vid time stamp 7 mins and 22mins
Replied by Clive S on topic 7i76e
No. You can't get 5v from the drivers you get it from the mesa card.That’s what I had previously. I’m not sure where to exactly get the 5v from. Not which jumper to change. I’ll read further and keep trying to see what jumper and where to get it from
From the manual:
LOGIC SECTION POWER
7I76E power.
From the manual:
TB2 PIN SIGNAL
1 GND
2 STEP0-
3 STEP0+
4 DIR0-
5 DIR0+
- Aldenflorio
16 Jan 2022 18:05 - 16 Jan 2022 18:14 #232083
by Aldenflorio
I greatly appreciate your help, very much so. I also thank you for all your time and research. I’m having a really hard time understanding all of this and I apologize. I’m not sure what to do I just don’t understand. I’m sorry. I hate to ask again, but I think it’s the only way I can really understand what I have to do. Is there any way you could Video chat for a few minutes just to help me a bit more visually. Again I deeply apologize and appreciate what’s you’re doing.
also, I get 5v from p1 and p6
So my board powered by a 12v power supply actually as well as the pins on the t3 section that require power
Essentially what I’m confused about is where to put the wires and where the come from with the 5v you showed me earlier on the Mesa board
Last edit: 16 Jan 2022 18:14 by Aldenflorio.
- Thank you received: 4154
17 Jan 2022 00:22 #232090
Replied by rodw on topic 7i76e
Each mesa stepgen has +5v and -5v for convenience.
As Clive said and as my video says, start with a multimeter. to confirm 5 volts.
- Aldenflorio
17 Jan 2022 00:43 #232093
by Aldenflorio
5v is confirmed. Between pin 1 to pin 6 reads 5v
17 Jan 2022 01:08 #232096
Its handy to use if you need 5 volts.
So the good news is you don't need to use it to set up step and direction.5v is confirmed. Between pin 1 to pin 6 reads 5v
- Clive S
17 Jan 2022 02:53 #232099
by Clive S
Rod am I reading this wrong. Why don't you need 5V when setting up single ended step/dir
17 Jan 2022 03:27 #232100
With a variant of the DM542, I just connected step+ and step- to pul+ and pul- and the same for dir.
Thats all I've ever done on any stepper driver.
I don't know what you mean by single ended. I assume it involves common signals. There is no place for it in the mesa ecosystem. Leave that to the Mach and grbl afficiondos.
- Clive S
17 Jan 2022 04:29 #232104
by Clive S
Well I am sorry Rod but you are completely wrong in my opinion there are plenty of drives that can't accept differential inputs.
From the manual:
STEP/DIR INTERFACE
The 7I76E provides five channels of step/dir interface with buffered 5V differential
signal pairs. Each differential pair consists of two complementary 5V outputs. The
differential signals allows reliable signal transmission in noisy environments and can
directly interface with RS-422 line receivers. Step motor drives with single ended inputs
connect to just one of the STEP and DIR signal outputs, that is either the STEP+/DIR+ or
STEP-/DIR- signals, with the unused signals left unconnected at the 7I76E. The input
common signal on drives with single ended inputs connects to the 7I76Es GND or 5VP
pins depending on the drive type.
This is mudding the water for this guy by you saying he does not need 5V
From the manual:
STEP/DIR INTERFACE
- Clive S
17 Jan 2022 06:03 - 17 Jan 2022 06:12 #232108
by Clive S
OK you have 5V + on pin 6 on TB2 that's good
connect pin 6 Which is 5v+ to PUL+ and DIR+ on the drive
Connect pin 2 to PUL- on the drive
Connect pin 4 to DIR-
One more thing check the switches on the drive for a start (sw5 set to on sw6 off s7on s8on)this should set the drive to 800 pulses/rev
Just get one axis moving first this is for your X axis
Don't waffle just keep to the facts
One more thing DO NOT Connect any power to P3 (which is 5v power in)
Last edit: 17 Jan 2022 06:12 by Clive S. Reason: added text
Time to create page: 0.373 seconds
