I downloaded
linuxcnc-2.8.2-buster.iso
and burned a DVD and booted i.
I did a graphic install overtop the existing Deb10 partitions (I have a /boot and a /root) without altering size, although I did direct them to be reformatted.
There was a bit of panic on my part when I saw DHCPv6 come up, because I don't run v6, but it seemed to get by that and continued to the end.
The only real difference was that I asked GRUB to be put on the second disk, /dev/sdb, where these new Deb10 partitions are. (There are three hard drives, and at one point I had the bootloader identically on all three.)
When the install finished, I went to boot the hdd and it failed, saying it couldn't find a partition. I hadn't simply accepted the default boot option, but looked at the proposed Debian 10 menu item with the 'e' option--and noticed that it was going to boot an "rtai" kernel! That seems like a holdover from the previous install.
I had definitely instructed the installer to reformat both the /boot and /root partitions and even to zero-out the /boot partition. (None of the Deb 10 GRUB entries on any of the disks' boot menus mentioned the rt image: only rtai.)
I was indeed booting from the /dev/sdb because I accessed a Boot Menu during booting (in fact I've tried booting from all three) so I just decided to "Start Again."
This time, the DVD drive boots but after I select Graphic Install (or Install), it hangs at the DHCPv6 step: 30 min and counting at this point. It shows an empty blue screen with an empty white bar below. I doubt it will come back unless a DHCPv6 server spontaneously appears.
I'm going to try to boot into a Live session and give it a fixed IP address, however that's done, and then launch the install again from there.
Can you tell me the pathname to the installer?
