- Thank you received: 13
@BigJohnT:Stepconf is meant to make a usable config, and it does that perfectly.
For changing the timings and fine tuning, editing the .hal and .ini files in the config/ folder is the way to go.
In the .ini file there will be:
- BASE_PERIOD - set this depending on the jitter value plus 50% to be on the safe side
- steplen and stepspace- set this to 5000 and lower it gradually to where you are sure there are no missed steps from the drives, forget what drive manufacturers say about this
- dirsetup and dirhold- set this to 20000, it does not matter much if you go lower or higher, but to low can cause very strange missed steps
@andypugh:Stepconf does have some limits and once you get a basic configuration editing the files is the way to go.
It begs the question:There is no advantage in having dirhold and dirsetup short. The machine is by definition moving at zero speed at that point.
If you want shorter step lengths, then edit the .ini file.
The chances are that the max speeds that you have configured mean that stepconf sees no need to use a short step length, as the max required step rate can be achieved without.
