(I misremembered the name anyway; it was called
"Colossal Cave"
and it was played on pre-Commodore "mini-computers," like the PDP-11. I encountered it first on a VAX and then on a later port to the Zenith Z-100.)
Fear kept me dragging my feet on doing the RTAI install. I am something of a fool however, as I quickly re-learned when finally forcing myself to the task. One of the most trivial things I've done wrt to LinuxCNC.
Having followed
the steps (Sec. 7.2)
and rebooted, the 4.19.195-rtai kernel was not offered on the grub menu.
I located it on the boot partition associated with the version of Debian 10 I'd originally installed the RTAI on, but have not been successful getting it to be one of the menu choices. In trying to get it recognized (by update-grub) I managed to muck up the system so the original Debian 10 won't boot either. (I am something of a fool...)
I still have a booting version of Linux Mint which I'm using to try to straighten out the booting.
(Debian's boot error says "file <old-vmlinuz-rt-amd64> not found" and that I have to "load the kernel first".)
When I learn how to edit a grub entry to add the paths to the rtai files, I'm sure it will boot again, after which I'll try to run update-grub again.
