loading LinuxCNC on old smithy 1240
4 years 1 day ago #255612
by LPMattei
Replied by LPMattei on topic loading LinuxCNC on old smithy 1240
I ran halcmd again, with switch jumped out and gui up and system homed smithy@debian:~$ halcmd show pin *8i20*
Component Pins:
Owner Type Dir Value Name
9 float IN 0.3333333 hm2_5i20.0.8i20.0.0.angle <== rotor_angle
9 float OUT 328.32 hm2_5i20.0.8i20.0.0.bus-voltage ==> voltage
9 float OUT 40 hm2_5i20.0.8i20.0.0.card-temp ==> temp
9 float IN -0 hm2_5i20.0.8i20.0.0.current <== current
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.U-current
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.U-current-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.V-current
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.V-current-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.W-current
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.W-current-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.bus-high
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.bus-high-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.bus-overv
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.bus-overv-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.bus-underv
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.bus-underv-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.framingr
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.framingr-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.module
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.module-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.no-enable
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.no-enable-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.overcurrent
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.overcurrent-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.overrun
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.overrun-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.overtemp
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.overtemp-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.watchdog
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.watchdog-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.brake-old
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.brake-old-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.brake-on
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.brake-on-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.bus-underv
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.bus-underv-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.current-lim
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.current-lim-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.ext-reset
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.ext-reset-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.no-enable
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.no-enable-not
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.pid-on
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.pid-on-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.sw-reset
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.sw-reset-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.wd-reset
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.wd-reset-not
smithy@debian:~$
Component Pins:
smithy@debian:~$
4 years 1 day ago #255613
by LPMattei
Is there maybe something here that needs changed?
# Spindle Contactor Enable
setp hm2_5i20.0.gpio.041.is_output TRUE
setp hm2_5i20.0.gpio.041.invert_output TRUE
# Door Closed - Energizes spindle contactor
net CLOSED hm2_5i20.0.gpio.029.in_not hm2_5i20.0.gpio.041.out
4 years 1 day ago #255625
Replied by andypugh on topic loading LinuxCNC on old smithy 1240
It looks like the 8i20 has volts and is enabled.
Open the halmeter and / or halshow and follow the spindle.0.... pins through.
There is a pid component for closed-loop spindle control, and then the bldc component, so quite a lot of places a signal could be getting lost.
Look at the signals and pins here, especially 8i20.current:
This might need to be 30, now:
That could be limiting the motor to 1A.
net current bldc.0.out hm2_5i20.0.8i20.0.0.current abs.0.in
setp pid.0.maxoutput 1.0
4 years 1 day ago #255627
by LPMattei
setp pid.0.maxoutput 30 did it. Spindle now runs.
Anything else to test before calling it good?
4 years 20 hours ago #255676
You probably need to adjust the spindle PID settings too (these are direct in the HAL file rather than the INI)
Possibly they need to be 30 x bigger but I would try going up in stages. You are aiming for good speed control under load, but without any oscillation or overshoot.
But, I think it is time to try making chips.
4 years 17 hours ago #255686
by LPMattei
Super, thank you, I will try that next.
Next step is to get MPG to work, I have been reading the instructions and am a bit lost, docs say the files are in there for versions above 2.6, but I'm not sure exactly what needs to be done to make it work.
Time to create page: 0.172 seconds
