loading LinuxCNC on old smithy 1240
4 years 8 hours ago #255710 by LPMattei
I'm sorry, I thought I mentioned it earlier. I have an xhc-hb04 wireless I want to add, it is the main reason I decided to go with the new SW as it was not able to run with the old Ubunto version,
4 years 8 hours ago #255714 by andypugh
In that case ignore naiky.hal (including the version that I wrote for you :-/)
I have never used an xhc pendant so cant really help.
4 years 7 hours ago #255716 by LPMattei
Again, I apologize and also for any trouble, I'm just trying to do what I can with this old beast. I have been reading all the docs and following all the questions and answers, but I realize I don't understand enough to even understand the replies. I've made changes as I believe I understood, but even when gui came up, pendant didn't work even though it seems to in manual test mode.
4 years 7 hours ago #255717 by andypugh
Halscope and Halshow (both accessible from the "Machine" menu are the way to diagnose this sort of thing.
Especially the Halshow "Watch" tab where you can display multiple inputs and outputs.
Try jogging both homed and unhomed. You might see different results. If you do, I can explain.
4 years 7 hours ago #255724 by LPMattei
Thank you, I need to get it back to the gui coming up. I have made so many changes following the help and docs, I thought I was able to get it back, but not yet.
3 years 11 months ago #255810 by LPMattei
Well I got the gui back up. I see the lcd display now responds when I move x.y.z from the kbd, but no function from the mpg.
As for "Halscope and Halshow (both accessible from the "Machine" menu are the way to diagnose this sort of thing.
Especially the Halshow "Watch" tab where you can display multiple inputs and outputs."   Honestly, I'm lost. it's like your talking rocket science, and I'm here still trying to figure out how to bang 2 rocks together (;->). I really thought this would be easier. There is a ton of info in the forum on this, but I feel it is geared to those that already have some understanding of how this works. I have been reading and reading and trying. I found a video where it was explained on a much lower level, still a bit over my head, but I could reach for it, and I realized there were a bunch of info relating to the buttons that needed to be added to my ini file, that explains why I felt like I was missing something. I assumed (incorrectly) that when the xhb-h04 was now included in v2.6 and up, that it would just run with minor tweaks. Well, I will continue to try to learn some more, if you can maybe point me somewhere to get more info on the basics, ie: files needed, what they do, where they go, how they interact, anything helps at this point. If not I understand, I've taken up a lot of your time so far.
Time to create page: 0.094 seconds
